Results 1 to 8 of 8
Thread: Phenol Red
    Jun 2013
    Southeast Pennsylvania
    125
    Phenol Red
    Hi. I have a Taylor testing kit. Bought it last year and it came with Taylor brand Phenol Red. My pool store has Phenol Red, but it isn't the Taylor brand. Can I use that? If so, will I add 5 drops like my Taylor brand. Lastly, will it be compatible with the Taylor brand acid demand drops
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,029
    Re: Phenol Red
    Hi,
    yes you can use the Phenol Red to test for pH, and it uses 5 drops.
    I cant say for sure though that it will work with the acid demand, but I expect it will.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Phenol Red
    Quote Originally Posted by dubele View Post
    Some are different...For instance, the Taylor K 2006 pH test takes R0004 reagent while the K-1000 or TF100 takes R0014. These are not interchangeable at all as they are different concentrations. I would suggest making sure you have the right one with no questions about it.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,029
    Re: Phenol Red
    Thanks for clarifying that Patrick,
    I wasnt sure at all about he acid demand part.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Phenol Red
    I am Colonel Shultz on the Acid demand test.
    (I hope someone gets the reference)
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Phenol Red
    Quote Originally Posted by Patrick_B View Post
    You mean Sgt. Shultz? I know nothing, noothiiiing.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Phenol Red
    DOH..Need more Coffee!
    Yes, thank you!!
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Phenol Red
