Results 1 to 13 of 13
Thread: I started up my own pool!!!!
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Cool I started up my own pool!!!!
    Okay, so the poll company didn't show up to start up my pool. So I said fine! I'll do it myself!
    Here's my initial reading after start-up and 2 gallons of shock (not enough, I know, it's all I had on hand, since the pool company didn't show)
    5/16:
    FC:1
    CC: 3
    TC:4
    CH: 150
    TA: 300
    CYA: 0 <- YIKES!
    PH: 7.8 <- Not too bad!
    Someone remind me how I am supposed to lower my TA and raise my CYA??
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    Re: I started up my own pool!!!!
    Lynzizzle- good for you for taking charge! It looks like you need to do a SLAM with a cc >.5. You will need to buy stabilizer (CYA) and add that to your pool. Just use pool math to help figure out how much you'll need. There is also a CYA/Chlorine chart in pool school so you will know how many ppm of chlorine you'll need for your level of CYA. When I started out, I shot for the 30-40 range. Just make sure your chlorine SLAM level coordinates with the amount of CYA that you've decided on.
    TA is a frustration for me right now as well. It drives your pH up quickly, so make sure to lower your pH to 7.2 with MA before you start your SLAM. TA will decrease with time as you lower your pH. Aerating your water is a good way to lower pH - think rain, kids splashing around or fountains. PH test results are unreliable during SLAM.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Im sure this was a typeo, but just to clarify....
    Aeration actually rasises pH.
    To lower TA, does with MA to lower pH and TA and aerate to raise pH
    Quote Originally Posted by S1ngram View Post
    TA is a frustration for me right now as well. It drives your pH up quickly, so make sure to lower your pH to 7.2 with MA before you start your .... . .... Aerating your water is a good way to lower pH - think rain, kids splashing around or fountains. PH test results are unreliable during SLAM.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Congratulations on doing that yourself!!
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The big question: what does the water look like?
    High CC and low CYA could point to Ammonia formation. There's a lot of that this year.
    Your TA may not be that high. Did you wipe the tip on the bottle of reagent? Static electricity can cause the drops to be smaller than they should be giving you a false high reading.
    CC that high means a SLAM is needed. But hold your horses....
    My advice: target 7.4 pH first using acid. If you end up below that, it means TA wasn't as high as you thought. Next, take FC up to 8 or 10 and brush a little while the pump is also mixing things. Half an hour after adding, take FC & CC readings. If CC has gone up even more and FC has gone way down, you have ammonia. Post back and we can walk you through it.
    Once the CC starts to drop, then you'll be wanting to get some CYA in there and proceed with the SLAM as usual.
    S1ngram's Avatar
    Jun 2014
    304
    Thanks for the correction Divine Dave! I'm still learning
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Before you start adding chemicals, did you let the pool pump run for an hour before testing the water? If not let the pump run and do the tests again.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Good stuff, congrats!
    Welcome to TFP!
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    Use PoolMath to figure out how much to add.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    TFPC for Beginners
    I already have my test kit as I used the TFP method last year.
    All - I went ahead and added CYA to the water via sock method to slowly integrate into the system. My pool is clearing up rather quickly actually and holding Chlorine steady at 10. Yesterday's CC reading was down and PH down to 7.2.
    SLAM is already in full effect.
    Water is clear. A little green from algae growth but the algae is dying.
    I'll get you guys a reading tonight.
    Lynzizzle
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    5/17:
    FC: 10.5
    CC: 0
    TC: 10.5
    CH: 250
    TA: 290
    CYA: 0
    PH: 7.2 <- Dropped drastically.
    Didn't get a reading last night as it was basically tornado-ing. Update this evening.
    Lynzizzle
    DFW, TX
    24,450
    OK, we accept that as a valid reason for not testing.
    PH test is not valid when FC is above 10.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    5/19
    FC: 8.5
    CC: 0
    TC: 8.5
    CYA: 0 - filled another sock tonight to bring it up - should I pour directly in slimmer instead like directions say?
    PH: 7.5 - right in the money!! 🏼
    Lynzizzle
    DFW, TX
    24,450
    No, pouring it in the skimmer sends it straight to the filter. Sock is better. Squeeze the sock a few times a day to speed the process up.
