Results 1 to 10 of 10
Thread: The "Mom Guide" to converting your Summer Escapes pool to use a sand filter
    MineolaMom's Avatar
    May 2015
    Mineola, TX
    4
    We purchased an 18' x 42" Summer Escapes pool last summer, and I made the decision a few weeks ago to purchase a sand filter for it as we opened it for this summer. After haunting this site and others for weeks, trying to gather enough information to make the switch, I saw others with the same problem: moms who are not hardware-savvy and just want straightforward how-to advice (and weren't finding it). I purchased a filter, and when it arrived, I realized the hoses weren't compatible with what I had (none of the spec info I read when purchasing it gave me any clue that it wouldn't fit my existing connections). It took two trips to the hardware store and two more orders from Amazon to finally get everything figured out and set up after days of trial-and-error and frustration. So now I want to offer these instructions to other "mom-types" who just want a step-by-step solution. I'm going to tell you about my specific situation/setup...
    Again, we have an 18' x 42" metal-frame Summer Escapes pool (not a Pro Series or anything Ultra-whatever...): white metal frame with blue vinyl liner. The skimmer says SFS1000 on the side. It did not come with plunger valves or anything like that...So, moms, here is what you should purchase if you want to add a sand filter to an 18' x 42" Summer Escapes pool with an SFS1000 skimmer filter (don't know personally if this will work for any other equipment configuration):
    1. Purchase your sand filter: After research, I bought this one for my particular pool (and you have to go buy sand too... two 50-lb bags of pool filter sand, and you'll use about half of the second bag): http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    2. Purchase a conversion piece that will allow your filter to "plug" into the bottom of your existing skimmer:
    3. Purchase these hose adapters (make sure you get a pair):
    4. Purchase a 1.5 to 1.25 reducer coupling... I bought mine at Ace Hardware. It is part #4224044. You can probably find something comparable at your Lowe's or Home Depot. (looks like this) Attachment 36485
    Now...
    1. Put your sand filter together according to the instructions, fill with sand, etc.
    2. On your old skimmer, take off the white accordion hose that ran from the black pump to the water return nozzle (my hose had metal clamps). Remove the old black pump out of the bottom of the skimmer (you can discard both this pump and the old white hose). Stick your new conversion adapter into the hole in the bottom of the skimmer and secure it with the locking ring. Attach one of your new hose adapters to it, and screw the hose that came with the new filter onto it. (see photo #4441 in the shared folder below)
    3. On your water return nozzle, add the reducer coupling. Then use your second hose adapter to attach the hose for the new filter. (see photo #4438 in the shared folder below)
    4. The pic of my entire finished setup is #4442 in the shared folder below.
    https://drive.google.com/folderview?...Uk&usp=sharing
    Casey's Avatar
    SW PA
    10,421
    Re: The "Mom Guide" to converting your Summer Escapes pool to use a sand filter
    Welcome to TFP. Your tutitorial should help others. Thanks for posting!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! Great tutorial!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Hi Neighbor!
    Nicely done post and tutorial! This for sure will help someone someday.
    Divin Dave,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I vote for a ......."sticky".
    Orlando, FL
    690
    Your tutorial is great and will definitely help others. The only thing that I would add is to place the filter in the proper location before filling it with sand. They are very heavy and awkward to move when they are full and it is even harder when the sand is wet.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP! That is one dandy first post!
    Here is a link showing how to update your signature, What we need to know to answer your questions
    n9udt's Avatar
    May 2015
    Victorville
    8
    Welcome to TFP!
    Now that you did all that. Take a look at my post on that Backwash hook-up!
    http://www.troublefreepool.com/threa...-They-will-Too!
    Intex Easy Set Round 15' x 36" 2,800 Gallons above-ground vinyl pool, Intex Krystal Clear Sand Filter Model FS70110 with GFCI, and a pump flow rate of 2,800 gallons per hour. Clorox Pool&Spa 25-lb Sand Pool Plus. Shock = 8oz hth Ultra once a week. Sanitizer= hth Ultra 3" Chlorinating Tablets in Floating Chlorine Dispenser. Manual vacuuming using Weighted Triangle Swimming Pool Vacuum Cleaner Head Attachment.
    MineolaMom's Avatar
    May 2015
    Mineola, TX
    4
    I just bought another Intex hose just like the ones that came with the sand filter... it screws to the 1.5" threads on the waste port. It only sends the backwash water about 5 feet (it's a 59" hose)--into the grass next to the pool--but that's okay with me.
    http://www.amazon.com/Intex-Diameter...rds=intex+hose
    18' x 42" Summer Escapes AG Pool; Intex Krystal Clear Sand Filter Pump (2800 gallon)
    Apr 2016
    Fowlerville, MI
    25
    I know my response is late to the party. I don't care. What I DO care about is that this thread is EXACTLY the kind of bacon-saving info I needed and that I hoped to find. I took a wild guess that I might need the one kind of adapter. I did not know about the reducer from Ace Hardware or the funky stretched pyramid thing. Ordered both of those too. I also ordered a plastic pad from Home Depot to set the filter on. I'll level the area and embed that thingy in the ground. I think this might actually WORK!!!!!!!!!!
    Intex 16' dia, 5500 gallon above ground
