Thread: Gunnite and the Rain
    Mar 2015
    Pearland, Texas
    11
    It has been raining a fair bit here in Texas. We had enough clear days for the excavation and rebar. But the plumbing stub out and the inspection took longer than anticipated and the forecast for the last week has been rain, rain, rain.
    To prevent the excavation from caving in, the gunfire guys came by and "flashed" the excavation. A thin (1/8) coat of gunnite.
    We got a surprise call last night telling us that the gunner guys would be here in the morning to finish the job. They were nearly done when it started raining again in earnest. They quickly finished the job and tarped the whole pool.
    The PB has always been upfront and knowledgeable, but I am more than a little nervous. Is there any hope of a good cure? Does anyone have any experience with rain during gunnite?
    I'll post pictures as soon as I figure out how.
    Partially operational.
    17,000 g, SWG, tanning shelf, bubbler, slide grotto, Prism Matrix - Deep Blue Sea, 2x Hayward Ecostar VSP (one filter, swg, and bubbler; one slide and grotto).
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Gunnite and the Rain
    As long as they got it in prior to the rain you should be fine.
    They don't want the rain while they are shooting cause it is effectively diluting the mix and making it impossible to hold form.
    If the get it up and prevent it slumping before is sets up, rain is ok.
    Curing actually required regular wetting down to ensure the gunite achieves it's optimum strength.
    We were advised to hose it down several times a day for several days to do this,
    Some PB setup a sprinkler in the pool on a timer to ensure this wet down during curing.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    AlanE's Avatar
    Jun 2013
    Cape Haze Peninsula, Florida
    178
    Yup. We had nothing but rain when they did our pool. Was told by the PB that the afternoon storms were fine. They let the pool fill up with water (high water table) after they were done shooting it.
    23.6x14 IG free form ~8K gallon, Pentair VS 3050 Intelliflo, GloBrite LED lighting w/IntelliBrite controller, Aztec Cobalt water tile. CLI Carolina Blue pebble finish, Bronze pool cage, 336 sqft Heliocol solar heating. Build Thread and landscaping Solar heating install
    Feb 2015
    Santa Cruz, CA
    368
    Send your rain to California...we need it!!!
    I have several notes from our pool builder - one says we need to wet our gunite 4 times a day for 14 days...that is crazy. One says 3 times a day for 10, one says something else.
    In reality I think we will do it a few times a day for a week or so. When I asked him why, he said that the worst case scenario is covered by the 4 times a day for 14 and that would be over 100 degree days and really dry which I don't think we will get where we are located.
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
