Results 1 to 7 of 7
Thread: When and what conditions to test?
    May 2015
    Longwood FL
    9
    Do i test in the morning or evening? With the pump on or off?
    If I test with the pump on, should it be running for a certain amount of time before I test?
    I am getting my Taylors kit on Sunday. I am so over chain pool stores lack of knowledge and Bog box stores selling stuff that actually makes more problems.
    Thank you to the admins. I had gone through TFPC's Pool school tonight and want to punch some pool store employees.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: When and what conditions to test?
    You'll need some bright sunlight to do the CYA test. Otherwise, time of day doesn't really matter. Whatever works best for you. The pump should be on for at least half an hour before you test and half an hour after you add something.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP and congrats on taking over your pool! Richard covered the rest.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Personally, I like testing in the evening/night after the sun has hit the trees. It's a good time of day for me and I have my pump timer set to start for it's evening cycle for about 1 hr before I usually test. I also like this time of day as when I need to add bleach to the pool, the FC for the day will be at it's highest point overnight and not be consumed by the sun in any way until 8 hours later. Allows my FC to be closer to the target level for more hours in the day.
    Welcome to TFP and good luck! Ask lots of questions if things aren't clear after perusing Pool School and searching for similar topics on the forums. It's a lot to soak in, but once you put it into practice it will all come together.
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Remember once you get everything balanced and you get to know your pool's trends you don't have to do all the tests all of the time. For me that means testing FC/CC about 2- 3 times per week, pH every other week (my pH is very stable, and rarely needs adjustment), CYA about every 2-3 months, TA and CH 3-4 times per year (vinyl pool that does not need CH, and very low CH fill water).
    May 2015
    Longwood FL
    9
    I made the unfortunate mistake of spending hundreds of dollars at a pool supply store on CYA reducing solutions, Phosphate solutions, over priced Chlorine, conditioners, and everything else under the sun. I guess they saw me coming. 2 rounds of Bio-Active and my CYA level never changed. Ordered my Taylors kit yesterday off Amazon. Does anyone know of a good software to track pool test results. I love the pool math spreadsheet however I would like to track trends and gain a pool history... Any suggestions?. Also I hm totally against Big Box stores and chains at this point but I did see that Lowe's sells a 12.5% bleech solution. Any comments?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by kwamhoff View Post
    A lot of that Lowe's pool chlorine sits outdoors in the heat for long periods of time, slowly degrading. It won't be 12.5% for very long.
    If you can see a date code stamped on the box, you might be able to decode it and decide if you want to buy.
    PS: use the search box for spreadsheets.
