Results 1 to 8 of 8
Thread: Took full results with K-2006 first time
    Apr 2015
    Visalia CA
    30
    Pool is roughly 13.5k gallons
    Cya 90 (not sure if you go until the dot is completely gone, may be higher as I made sure to let eyes adjust and squinted )
    P.H 7.3-7.5 (looked like the color could sit between 7.2-7.4 and 7.4-7.6)
    TA 90
    CH 280
    FC 0
    my pump sucks in air and I have a guy coming Tuesday to help me get figure it out.
    Looks like I just need to add 280 oz of 6% chlorine? That's the highest strength I can find. Or is it cheaper overall to go get a stronger one from a pool store?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Took full results with K-2006 first time
    Glad you got your test kit! CYA test can be tricky, but you get the hang of it after awhile.
    Yes add bleach. You will likely find it in 8.25% just regular bleach. Make sure it says 8.25% on it and no easy pour splash less or scents. In pool math you can change the percent to 8.25% 6 is just the default.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Apr 2015
    Visalia CA
    30
    I was just basing that on the chlorine I actually have, it is 6%. Everything else look okay?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Jfdelman View Post
    Ah ok. Double check the date on it as if it is from last year it probably has lost strength. Your numbers looks good other hand FC which you know. As for CYA do you have a SWG? If so you probably want to lower CYA to around 75. If not then you will want to lower it to 30-50. To do this you will have to drain some water and refill until you get to where you want to be.
    Could you update your signature in settings with your pool, equipment and test kit info. It really helps us to know these things.
    Lisa
    Apr 2015
    Visalia CA
    30
    Finished, I think.
    Jeff
    30' x 17' plaster pool 13.5k gallons (roughly), The Pool Cleaner (two wheel), Taylor k-2006, Pentair WhisperFlo 1.0hp, Purex triton WhisperFlo .5 hp (no idea why there's two pumps)
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Finished, I think.
    Signature looks great!
    You don't show a SWG, so being in CA I would lower your CYA to around 45. Just do gradual drain and refill process. Drain just below the return then refill and repeat a couple times. Then re test CYA.
    How does your water look?
    Lisa
    Apr 2015
    Visalia CA
    30
    No SWG. I would love to get my CYA lower but we are in a drought and don't feel right wasting water. Water looks great, been blue since I moved in.
    Jeff
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You will lose some CYA with splash out and backwashing so that is fine.
    Lisa
