Thread: New to the BBB
    Jul 2008
    austin, tx
    9
    New to the BBB
    OK, so I'm in the process of switching over to the BBB method. Right now my CYA is at 90, which I know is higher than recommended. My plan is to gradually try to reduce that number over time. My concern is that according to the Chlorine/CYA chart my target FC is 10. I'd always heard that having a high FC level could ruin your pool/equipment, but what exactly could happen? So my question is what, if any, are the negatives of keeping my FC level at 10? I'm guessing that the answer has something to do with my CYA being so high, but just wanted to double check.
    Thanks in advance!
    15,000 Gal IG Plaster
    Hayward Sand Filter
    Hayward 1.0 HP Pump
    Hayward H Series Heater
    Really OLD Polaris Pool Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New to the BBB
    The CYA kind of slows down or buffers the chlorine's action, making your 10ppm seem like a much lower level. You'll never notice it.
