Thread: Noob have questions
    May 2015
    Atlanta-GA-
    69
    Noob have questions
    Hi
    We are looking at getting an above ground pool installed. It seems we will have to go with a small 12' one because we don't swim and just like to lay there enjoying a beer and space does matter. We have a small retaining wall and we want to put the least amount of pressure on it.
    So we went to our local pool place today and the brand they recommended is a "Distinction LX". My wife wanted to get a saltwater system but they said they didn't carry them anymore because they rust the pool frame and recommended a "Frog" system instead for $375 extra. Well I have been researching the frog system on these forums and have read only bad reviews so we will probably go with the regular filter. The filter they will sell us is "Hayward pro series" How is that?
    As far as ladder it will be an "AG ladder". I understand that I will need to replace the liner at some point, but how often is that? We are in Atlanta and the season runs roughly from May to mid September.
    Please feel free to comment on all or just one of the products listed above, I need some feedback on anything bad that you have encountered or saving bucks with chemicals.
    No kids will be going in the pool if that matters, just us in our early 50's and our daughter with her boyfriend who are mid 20's.
    Thanks so much
    Patrick and Kristina
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Noob have questions
    Welcome to TFP!
    Sounds like a plan! Don't need too much room for a floatie!
    No to the frog. The easiest way to chlorinate is saltwater, next best is bleach.
    Don't know about the filter or liner replacement frequency.
    Here is some reading on maintaining your pool
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to determine how much to add.
    May 2015
    Atlanta-GA-
    69
    Pooldv
    Thanks for the warm welcome and the links I need to learn
    Regards
    Pat
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    When you put your money down on the pool, go ahead and look at the link in my siggy line to check out the *preferred and recommended* test kits. If you're available to test almost daily at first, and add a little beach daily, you'll have a low cost, sparkling clean pool without iccky mineral frogs (expensive!) or the SWG.
    Now, when you want to later put more money down you'll be able to feel good about either a bigger pool or a SWG for kicks.
    Welcome- You're gonna love having some water to soak in on those hot Atlanta days
    May 2015
    Atlanta-GA-
    69
    Quote Originally Posted by Azgirl71 View Post
    Welcome to TFP!
    Thanks a lot
    Pat
