Thread: Need Advice on Water Balancing and Water Bugs
    Aug 2014
    Friendswood, TX
    15
    Unhappy Need Advice on Water Balancing and Water Bugs
    We finished our pool late last year and have been using Pool Math to keep it balanced. But something got away from us recently and we could use some advice I think. The thing I first noticed were bugs swimming in our water last night! Ewe! My research indicates that these are probably water boats and backswimmers which may indicate an algae problem? I haven't seen any sign of algae but last week we had a terrible rain and the pool was very murky in the morning. We tested the water and there was 0 FC. So we added bleach and got it back up very quickly. But a week later I notice these bugs. Here are our test results as of this morning:
    FC - 11
    CC - 0.5
    PH - 7.4
    TA - 70
    CH - 200
    CYA - 50
    Temp - 81
    Pool Math says to add 13oz (vol) Borax and 56oz (vol) Baking Soda which we added today. Tomorrow we'll add the recommended 71 oz Calcium Chloride.
    OK, so far?
    My question is, Should we have slammed the pool since the FC went to 0? We've never had any CC showing at all until this week, so something has definitely changed.
    Can we have your advice please?
    Thanks much,
    Lynn
    New 11000 gallon chlorine IG, Tanning ledge with flolite bubblers, 2 skimmers, 6 returns, LED lights, 18" raised spa, wet edge northshore caribbean pebble finish, Jandy 2 hp VS pump, Jandy 1.5 hp water feature pump, Jandy cartridge filter, auto chlorinator, 400k btu heater, travertine paver deck, zodiac mx8 cleaner, iAqualink and spa side pda
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Need Advice on Water Balancing and Water Bugs
    There's zero harm in bringing it up to SLAM numbers until you pass the 3 SLAM criteria. If your water looks good I'd bet it would be a day or two SLAM job. Just make sure you pass all three criteria.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    I agree. Your pool was exposed to a lot with all the rain and muck, things can easily be different. It might not hurt things to bring it up to SLAM level and monitor a few days.
    Aug 2014
    Friendswood, TX
    15
    I wanted to report back on my progress. I completed a two day slam and as of this morning, passed the three steps a successful slam. And this morning, the swimming bugs had moved on! Yay! Amazing how solving one problem fixed the other! Today, pool looks clear and bright even though it is overcast today. Thank you very much for this valuable site. We've ditched the pucks as our cya was getting out of control and now will only use TFP's method. I've attached pictures as it seems like many of you like them. Thank you again.
    Lynn
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    We do like a sparkly clean pool! Good job!
