Thread: New Pool owner with a somewhat simple question
    May 2015
    Brooklyn NY
    46
    Hello everyone. I just installed a 12x18 above ground pool and built a deck around the entire pool 1/2" below the lip. The skimmer is about an inch or so below the bottom of the deck. My question is what do you suggest I use as a top plate on top of the deck to cover the soon to be hole I will cut for skimmer basket access? The deck is a brown color. Thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New Pool owner with a somewhat simple question
    Welcome to TFP!
    Perhaps a hinged cover made from the wooden deck, presming its wooden.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    pic of deck?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
