Results 1 to 11 of 11
Thread: Pool came with the house, half full with leaves and bugs - do we drain?
    May 2015
    Ottawa, canada
    3
    We moves into our house during the winter and just took the cover off yesterday and what we found was really disappointing. It is half full of water which I know is likely the way to close a pool but that water is at least half full of leaves and other debris. It is an older above ground pool by Atlantic Pools and it has a 4 way vari flo valve filter (no idea what that means) made by Hayward Pool Products - says it's model sp 704 txc (if that matters). My plan is to attempt to remove the leaves manually with the skimmer as much as possible but should we drain the whole thing and scrub it then refill? What we would use to scrub it and what's the safest way to do so (get in the pool with sponges)? Thanks in advance!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pool came with the house, half full with leaves and bugs - do we drain?
    Welcome to TFP. You should be able to get a majority of the leaves out using a leaf net.
    I also highly recommend ordering a recommended test kit such as the TF 100 I have linked in my signature.
    Don't go to the pool store. In Pool School read the ABC's of Pool water chemistry. It is a great read.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    South Park, PA
    39
    I got a heavy duty leaf rake from poolsupplyworld.com for around $15. Made a world of difference compared to getting leaves out with a skimmer. Shipping was very quick too.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Hi, welcome to TFP! Since you don't state the age of the pool's liner, the safest course would be to scoop out as much muck and debris as you can with a pool rake (deep net for scooping up leaves) and then put the pool through the SLAM process . If your liner is old and you drain the pool there is a chance it could tear and any liner new or old will shrink if left empty in the hot sun for more than a day. Since the cover is off go ahead and fill up the pool. Set the filter to backwash then turn on the pump. Once the water in the sight glass looks clear turn off the pump and set the filter to rinse. Run the pump for about a minute, more if the water in the sight glass is dirty. Turn off the pump, set filter to filter then turn on the pump and let it run. Check for leaks in the plumbing while the pump is on.
    Look around the property and see if they left a pool brush, pool rake, and pool vacuum with skimmer plate and check their condition. Pool brush should have medium firm nylon bristles that don't shed or break off. Pool rake should have a net that is intact with no signs of dry rot. Vacuum hoses should be flexible without chips or cracks and seal well to the vacuum head and skimmer plate. The vacuum head should have medium firm bristles that don't break or fall out and no chips, cracks or signs or dry rot. The vacuum plate should also be free of chips, cracks, and dry rot.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Congrats on the new pool. Sorry it's a mess, we can help.
    No need to drain.
    Order a TF100 XL option from tftestkits.net
    Scoop everything you can out of the pool.
    Fill it up. Test when you get the test kit and post results.
    Read this, SLAMing Your Pool and get ready.
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    Use PoolMath to figure out how much to add.
    Casey's Avatar
    SW PA
    10,453
    You've been given excellent advice thus far. Welcome.
    May 2015
    Ottawa, canada
    3
    Thanks for all the great advice everyone! I've started reading through all your suggested readings and I tried to order the test kit XL version but realized they do not ship to Canada. Can anyone recommend a comperable test kit that I could either order online or get in store (I know the online way would likely be cheaper but the in store way may be much quicker for us).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, there is unfortunately a company up there that has an distribution agreement with Taylor for Canada. You'll have to find someone who carries the K2006, sorry.
    Essential Links:
    DFW, TX
    24,509
    Aww heck, sorry. Didn't notice you are in Canada.
    Jul 2014
    Oakbank, Canada
    389
    Here is Canadian supplier for Taylor test kits, located in Cambridge, Ont.
    http://www.waterandice.ca/taylor-test-kits.html
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2014
    Oakbank, Canada
    389
