Just wanted to show people the panels I just put up. 4-4x16ft panels from www.ressolar.com
4 Ea Aquatherm Solar Pool Panels 4’x16’
74 ft Stainless/Poly Hurricane Strap (4 rows)
20 Ea Strap Hold Down
8 Ea Strap Hold Down ClampW/Screws
5 Ea Header Bracket 2 Hole
8 Ea Collector Hose 1.5”x4”
2 Ea System Hose 1.5 x 7”
1 Ea Aquatherm Vacuum Relief Valve
1 Ea Aquatherm End Cap 1.5”
2 Ea Panel to Pipe Adapter 1.5”
20 Ea Stainless Hose Clamp
50 Ea #12 x 1.25 SS Screw w/Washer
1 Ea Check Valve Jandy 2” pvc
1 Goldline GL235 Pool Control Combo
4 Ea Alum Header BRKT, 1.5” Two Piece
Shipping via UPS $280
Tax N/A
Sub Total- $2,540.80
Total $2,820.80
Now i opted out of the Goldline gl235 and the Jandy valve and saved $481.82. So my total was $2338
Hope this helped some people. I installed everything with help in 4.5 hours. I used climbing gear and also a fall harness. Lay everything out on the ground and then bring to the roof. I did not mark anything prior to screwing down, just used the shingles as level reference(which i checked prior).
here is the whole house. Yes i am a little crazy for doing it myself, but i paid $8.85 a square foot.
Tax N/A
Total $2,820.80
