Results 1 to 17 of 17
Thread: New AquaTherm panels
    Apr 2015
    Brookline
    60
    Just wanted to show people the panels I just put up. 4-4x16ft panels from www.ressolar.com
    4 Ea Aquatherm Solar Pool Panels 4x16
    74 ft Stainless/Poly Hurricane Strap (4 rows)
    20 Ea Strap Hold Down
    8 Ea Strap Hold Down ClampW/Screws
    5 Ea Header Bracket 2 Hole
    8 Ea Collector Hose 1.5x4
    2 Ea System Hose 1.5 x 7
    1 Ea Aquatherm Vacuum Relief Valve
    1 Ea Aquatherm End Cap 1.5
    2 Ea Panel to Pipe Adapter 1.5
    20 Ea Stainless Hose Clamp
    50 Ea #12 x 1.25 SS Screw w/Washer
    1 Ea Check Valve Jandy 2 pvc
    1 Goldline GL235 Pool Control Combo
    4 Ea Alum Header BRKT, 1.5 Two Piece
    Shipping via UPS $280
    Tax N/A
    Sub Total- $2,540.80
    Total $2,820.80
    Now i opted out of the Goldline gl235 and the Jandy valve and saved $481.82. So my total was $2338
    Hope this helped some people. I installed everything with help in 4.5 hours. I used climbing gear and also a fall harness. Lay everything out on the ground and then bring to the roof. I did not mark anything prior to screwing down, just used the shingles as level reference(which i checked prior).
    here is the whole house. Yes i am a little crazy for doing it myself, but i paid $8.85 a square foot.
    Southern New Hampshire, 18x36 single roman end pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: New AquaTherm panels
    good work! I did my own install too. From much lower! Here's to warm pool water.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Congrats on the new panels
    Jun 2015
    Kingston ma
    57
    did you have a good experience with them? I just spoke with them and they said they are a turn key solution. Just wondering if they will sell me the panels for a DIY application. They ball parked 4-6k for my application including installing but i tend to think it will be closer to 4k since i dont have much area 20 x20 max. im hoping to get clsoe 400sq/ft. How much did it actually heat up your pool? i have a 20 x 40 and wondering if it will be worth it for around 40-505 coverage
    where did you buy your solar panels from? available from an online retailer?
    20x40 kidney IG vinyl liner built 2012
    27k gallon, Pentair IC60 SWG,
    pentair vs 3hp pump, triton sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might be interested in my solar upgrade thread from a few years ago too Solar Panel Replacement / Update
    Auqatherm was on my short list, but I ended up using Techno-Solis panels bought from Poolheatpumps.com (same panels are sold private label as Vortex panels by Solar Direct, but only in limited sizes, and only 1.5 inch headers, I opted for 2 inch headers). The basic standard Aquatherm panel is also sold as a private label panel by Elm Distributing. A number of the major brands of solar panels are also sold through private label programs, this lets the companies sell the same product through multiple distribution channels at different prices with different warranties (same product sold through dealers at a higher price with a longer warranty). This works by offloading the warranty servicing to the private label distributor instead of the manufacturer.
    Ike
    ps I do really like the optional aluminum Aquatherm heavy duty mounting clamps, in fact I ended up using them on my TechnoSolis installation. I was able to do this as the TechnoSolis 2 inch header coupler is within about 1/20th of an inch of the same diameter as the Aquatherm 2 inch coupler, I am not sure it would work with the 1.5 inch panels.
    Apr 2015
    Brookline
    60
    I love the panels so far, I have 256sqft and it's awesome for my 18x36. They are in the sun from 8 to 4 everyday so that makes the biggest difference. I bought from resolar.com, just call because they are very knowelagble and no way to order online . Using my heatpump and solar combined I would get a 5-7 degree rise in water temperature and 3 degree rise with just the panels. I would 100 percent order again if anything happened to them
    Apr 2015
    Brookline
    60
    My experience was fine, described my roof dimensions to them, they told me what I needed and sent them via ups. I did everything myself so no in person interaction was necessary
    Jun 2015
    Kingston ma
    57
    Thanks. They just quoted me 16$/ft or 5700 for my operation. I would have similar sun all day and about 48% coverage. Sounds like the diy install is straight forward. Might try it on my own
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Depending on the exact setup you go with I suspect you could save nearly half that as a DIY project.
    Ike
    Jun 2015
    Kingston ma
    57
    That's what I was thinking too but the same place jhamblett was quoted sent me 3,900 for parts which is over 10.50/ft. I found the panels on eBay for roughly 2k. Not sure what piping,controller, and hardware costs but think I would be around 2600 or 2800
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my experience expect a fair amount of so called nickel and dime stuff that is not included in the kits, such as PVC pipes, fittings, glue, pipe brackets, screws, roofing mastic, etc. all totalled probably around $250-$300, plus the cost of the panels and a controller kit. So your real savings may be a bit less than half.
    Apr 2015
    Brookline
    60
    Ask them why the difference.
    Apr 2015
    Brookline
    60
    Sorry about being upside down
    Jun 2015
    Kingston ma
    57
    Thanks will do. When is that from?
    Apr 2015
    Brookline
    60
    11 months or so
    Jun 2015
    Kingston ma
    57
    Ok great thank you
    Sep 2015
    Rome, NY
    363
    Cool...I may be looking at adding on the ground, like I see a lot of solar farms in NY popping up...
    Just posted at solarpaneltalk.com
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
