Thread: Thoughts on filling a new pool with these well water #'s...
    jjwalker's Avatar
    S. Louisiana
    198
    About to pull the trigger on our new IG vinyl pool. A concern of mine has been filling the pool initially for start-up; whether to use a water truck and city tap water (which is available to me) or just fill it from my well.
    We will have an 18x36 ~19,500 gals. Regardless of where or how I get my initial fill water, I will have to deal with maintaining levels so it's kind of unavoidable drawing from my well. Here are the numbers:
    Iron: .01 mg/l
    Manganese: .065 mg/l
    ph: 6
    0 hardness
    Obviously the manganese will have to be dealt with...but how? and ph will obviously have to come up, not too worried about...should I?
    thoughts from the forum?
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Thoughts on filling a new pool with these well water #'s...
    The only thing I know about metals in the water is this link to a metals article from Pool School. There are other people here who have dealt with them and might be able to help more.
    http://www.troublefreepool.com/conte...d-metal-stains
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you have the option to avoid metals in your supply water at a reasonable price, do so. The safe route is city tap water, which is even cheaper if you call the city and tell them that you're putting the water in the pool and it will not enter the sewer. Most cities will waive the sewer fees for those gallons, making the water very cheap.
    Just do a search here on the forums for people having issues with metals stains and you can see the headache that in your case can easily be avoided.
    Isolated Spa - 345 Gallons
    jjwalker's Avatar
    S. Louisiana
    198
    thanks guys for the advice...anyone else with suggestions?
