Thread: After bumping DE filter return water is cloudy for 30 seconds and is getting worse
    I am assuming I have some issue with a leak past the tubes that is slowly sealed with DE after bumping and returning to filtering mode. Anyone run into this and have a correction? Thanks
    20,000 gal. 16 x 36 Vinyl liner in-ground pool
    Hayward EC65 DE Filter
    Heat Siphon 5hp heater
    Installed in Spring 2000
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: After bumping DE filter return water is cloudy for 30 seconds and is getting wors
    Welcome!
    I have no firsthand experience with bump-type filters, but maybe this will draw some attention from someone who does.
    38,242
    Welcome to TFP!!!
    No experience, but logically, I am not surprised. The DE is what traps the dirt. When you bump, the DE and accumulated dirt is knocked off the fingers. When you start the pump, it does not surprise me that some of the dirt might get through before the DE recoats the fingers.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    You need to open up the filter and check that none of the fingers are torn and that all the o-rings are in good condition and positioned correctly.
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What zea said, while you are at it if you have not opened up lately you may want to do a good cleaning and acid soak to remove CH buildup, if you have high CH levels.
    Ike
    p.s. please update your profile with location (city and state, or region of state if in the US), it helps us give you better advice
