Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Can I accomplish any of this with Dichlor
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Just got my kit, drained my pool 64% of the very high cya water, and now have the following readings:
    FC:0
    PH: 7.9
    TA: 60
    CYA: 20
    I have list of things to add to water, can I accomplish any of this using my Dichlor granules I swore I'd never touch again?
    Only reason I ask is since I needed to raise CYA?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Re: Can I accomplish any of this with Dichlor
    Actually, I just looked at my iPhone app. Doesn't this answer my question that it would be okay to use just this once?
    TFTest Kits TF-100
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If you look at the full site version of Pool Math, once you have your pool volume entered, look at the bottom of the page (below the chart)
    Effects of adding chemicals
    You can use the pull-down to select dichlor and it will tell you the effect a specific amount will have on your chemistry.
    chiefwej
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    The short answer is, Yes.
    Remember that TFP is not necessarily about *not* using some of the available products. We are all about knowing what they do and what they will add to the water.
    If you understand that the dichlor is going to add CYA along with FC (which it looks like you do) then all that is left is to calculate how much you can add to get closer to your goals.
    Like you found on your app and chief suggested in PoolMath...you can get an idea of what the dichlor will add and make your dosing decision based on that. Be careful and don't overshoot your CYA. What a pain to have to remove water again to fix that!
    Knowing what you're adding and how it affects your pool *is* the TFP way!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, that's a perfect use for dichlor...adding FC and CYA to fresh fills.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    yup. As long as you understand what happens, then you are in GREAT shape to take total control of your pool, and your pocketbook!
    Divin Dave,
    38,285
    It will also lower the pH ... you have the perfect combination of needs.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I was thinking the same thing with my new fill and was going to ask the same exact question
    you have to love the feedback and knowledge on this site...
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    And unlike the pool store, pretty much everyone who replies all give about the same answer!
    Quote Originally Posted by cowboycasey View Post
    Divin Dave,
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I didn't quiet have the effect I was hoping for.
    FC:0
    PH: 8.2
    TA: 90
    CYA: 30
    I added about 7 ounces of Dichlor with seemingly no effect.
    Any suggestions? 7 more ounces of the Dichlor?
    TFTest Kits TF-100
    38,285
    Are you using PoolMath to calculate how much to add?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Quote Originally Posted by cfclay View Post
    FC:0
    PH: 8.2
    TA: 90
    CYA: 30
    How the heck did the TA climb that much? The CYA should have only climbed by about 2, which is hard to detect n a test. The pH should have come down some. The FC not changing doesn;t surprise me - it is a consumable and you only added 3 ppm, which can disappear in a day no problem, even if there are no problems.
    I suspect some kind of testing error, or you've been adding some hard fill water.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Sure, I had the picture in a previous post
    TFTest Kits TF-100
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    When you are testing for TA- do you count when you get the first hint of pink/red? If so, okay you could probably dial that back back to 70.
    TFTest Kits TF-100
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    7 oz of dichlor in 10k of water would only raise CL by 2.9 which could be consumed pretty quickly, but there is no way it would raise the CYA by 10, or raise (not lower) the pH and TA like that.
    There must be an error somewhere. Possible testing error?
    chiefwej
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I don't know guys maybe I have selective color vision issues. My wife thought the on the first test was 8.2 rather than 7.9.
    As far as the TA? Honestly it's probably the same- first sign of solid pink-60
    TFTest Kits TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    You are on the edge of getting some algae going in your pool. FC must stay above the minimum level for your cya at all times, Chlorine CYA Chart
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    Update:
    FC:0
    PH:7.5
    TA:80
    CYA:40
    Just for kicks I did calcium test, because I notice original homeowner had calcium increaser in garage: 75
    The pool is getting less green but not clear. Looks chalky light blue maybe. Has never had any chlorine reading though I had been adding Dichlor for 2 days, then switched to 8% bleach the last two days. I'm on day 4 of treating this drain and refill. The 25% that was left in the pool was pretty green.
    I never thought calcium was something to worry about in a vinyl pool.
    So do I add the recommended 286 oz of calcium increaser??
    TFTest Kits TF-100
    Richard320's Avatar
    Jan 2010
    19,000
    You don't need to worry about Calcium in a vinyl pool.
    Odds are what happened was the previous owner went to the pool store for a free water test and they alerted him to his low CH and sold him a bunch. Ka-ching!
  20. Back To Top    #20
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    So hopefully now the CYA is where it should be the chlorine will hold not burn off so rapidly and do more of its job ?
    TFTest Kits TF-100
