Thread: Main Filter Pump not working - Help please!
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    I was gone for 2 days and returned to find my main filter pump is not working. Everything was fine when I left.
    Cleaned all baskets, opened and cleaned filter cartridges.
    Impellers are spinning, pumps runs for 5 seconds and then shuts offs. I tried replacing the pump start capacitor but that did not help. Pump makes a buzzing sound and gets quite hot with a little smell while is is on for those few seconds.
    Since I opened the system I did try to pour in several buckets of water but this did not seem to change much of the outcome.
    Appreciate your input - Please help!
    Thanks
    Rawlins
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Main Filter Pump not working - Help please!
    Buzzing, gets hot, and smell (assuming electrical type smell) it sounds like your motor windings are failing. If they are, your only recourse is to replace the motor. The reason for the shutdown is the thermal overload is tripping. When it cools off, it resets.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
