Thread: Pool Light Replacement Conduit Plugged
    wjr75's Avatar
    Jun 2013
    IL
    836
    Hello,
    I have a pool company out right now trying to replace my pool light and seal off the leak to the conduit. At the cross box there is sealant in the conduit at a the bend about a foot in and they are having trouble clearing it. They were pulling out the old wire cable and it broke off in the conduit. Any idea's how to clear the conduit path at the turn of this sealant? Thanks!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Pool Light Replacement Conduit Plugged
    If it was adherent enough to break a pool light cable, it is a real doozie.
    So it is gummed up 1" from pool light fixture right.
    Did they pull the rest of the cable back the other way? For long runs there is an above grade junction for this cable.
    Can air get through?
    If you squirt some cable fishing lube into conduit and suck it through with a shop vac 1st.
    Then use a flexible pole; fiberglass tent pole, thinner conduit. and sleeve it in from pool fixture end and try to dislodge the sealant.
    The lube will help after the initial adhesion gives way.
    I had to clear mortar out of mine and after enough curses to preclude me from the holy fathers presence I got it out.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    a small manual roto rooter might work. If you can find one small enough might be the challenge.
    Divin Dave,
    wjr75's Avatar
    Jun 2013
    IL
    836
    Thanks for the advice. They finally got through it after working on it for 8 hours. I have a nice multi color LED now!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    awesome!
    Now you can add that to your sig!
    Divin Dave,
