Thread: pool shocking
    bobby g's Avatar
    May 2015
    southern, ct
    21
    pool shocking
    Hello Everyone,
    I am new to TFP my question is on shocking pool upon opening for the season. I went to the pool store and explained that my pool was green, so they sold me 3 cases of shock and instructed to put all in at once and to leave the pump running so we did, it did turn the pool cloudy blue. when I check the chlorine levels in the morning there was some and when I come home after work all would be dissipated. After reading the threads on the forums about not having stabilizer and that what helps keep chlorine in pool just curious why they didn't tell me that I should have used a chlorine with a stabilizer in it if there is such a thing.
    Thanks, Bobby G
    15000 GALLON POOL/ VINYL LINER
    SWG/ T-3 HAYWARD TURRBO CELL
    PENTAIR CC200 CARTRIDGE FILTER SYSTEM
    HAYWARD SUPER PUMP 3/4 HP
    RAYPAK HEATER
    22,542
    Re: pool shocking
    Welcome to TFP.
    If the so called shock they sold you was granular, it most likely contains lots of CYA (stabilizer). Also, your pool most likely has more than enough CYA already and they've just made it worse.
    I suggest you get a good test kit and do your own testing and while you're waiting for it to arrive, read the ABC's of Pool Chemistry.
    bobby g's Avatar
    May 2015
    southern, ct
    21
    Re: pool shocking
    Thanks Dave,
    The shock they sold me was a liquid super shock, so they do sell a granular that has stabilizer in it, any brand that you recommend?
    RAYPAK HEATER
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pool shocking
    Ok I see you started a thread from the PM.
    Welcome again to the forum.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: pool shocking
    Step one is to get a good test kit so you know what is going on. Sadly pool stores can't be trusted.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    22,542
    Re: pool shocking
    The liquid they sold you doesn't contain CYA and that's a good thing.
    I don't recommend any stabilized chlorine, and I would strongly recommend against it when I don't know pretty certainly what the existing CYA level is. Pool stores are notoriously bad at testing CYA. Get a good test kit and test the CYA then make an educated decision about whether you need any or not. You simply need to SLAM.
