Thread: how to read hayward aqua rite display
    May 2015
    whellerburg ohio
    8
    I just installed a new in ground pool last yr. 16x 32 x5ft deep end to 3ft. at other end.And had a hayward aqua rite Chorine Generater installed. But I don't understand the readings and what they mean. Can some direct to an understanding on these reading and what I need to do. And does the salt control the PH and Alk or to I have to get chem. to do that. Thanks! I'm new here as Of today.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: how to read hayward aqua rite display
    Welcome to TFP!
    Here is a thread that seems to cover the Aqua rite numbers. It is only related to the SWG, nothing to do with the other water chemistry parameters.
    http://www.troublefreepool.com/threa...rs-on-LCD-mean
    and a search result with lots of info.
    https://www.google.com/search?sitese...y=0&gws_rd=ssl
    Here are some intro Pool School articles to read that will answer your questions about FC, Alk, etc .
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for your SWCG pool.
    Use PoolMath to figure out how much to add.
    May 2015
    whellerburg ohio
    8
    Thank you very much. I'll get to reading.
    DFW, TX
    24,483
    Alright! After you get all that memorized come back and ask some more question. It only took me 30 or 40 times.
    May 2015
    whellerburg ohio
    8
    Pooklv, i probably will never get it. It seems like once I read something the next day I don't remember what I've read. Might have something to do with getting older, Thanks again for the reply. I need all the help I can get.
    DFW, TX
    24,483
    groovy, how about updating your signature with your pool info as described here.
