Results 1 to 8 of 8
Thread: Dolphin Nautilis and Fiberglass pools and wall climbing
    May 2013
    North East Ohio
    959
    so got my new robot (named mr. button by our son) into the pool for the first time.
    only issue is it NEVER makes it up a wall...not even close.
    somewhere I read (but can't find it now) that there are rollers made exclusively for FG pools, and the combo roller it comes with will NEVER climb a wall.
    does this make sense, or was I dreaming.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Dolphin Nautilis and Fiberglass pools and wall climbing
    I've never heard of one, but who knows? We use a simple pressure side cleaner thingy Polaris 165. My fiberglass pool has a short ledge around the sides which would hinder my use of anything fancier.
    Good luck and if you find something out please share details?
    May 2013
    North East Ohio
    959
    So I get the ledge, but mine does not even get up to the ledge. Plus I have sections that have no ledge and same issue. The robot gets vertical then just spins.
    PLUS - I found these brushes....Maytronic's CS SWEARS the normal brush should climb FG walls, but they don't and only want to sell me more brushes. So in for repair goes my brand new robot
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The robot wont and isnt intended to climb to the top of the wall every time.
    Sometimes it will just roll the front scrubber onto the wall, stop, and then go backwards.
    Other times it will position itself vertical at bottom and then go backwards
    Other times climbs completely up...
    On yours, are the scrubbers still turning but just wont go up?
    If the scurbbers stop, then the cleaner falls of or goes backswards, then thats what its supposed to do.
    If the scurbbers are turning but then falls off, then give it a couple days for the scrubbers to break in... it may be just fine after a couple days.
    Divin Dave,
    Jul 2014
    Outer Banks, NC
    23
    I have the dolphin nautilus plus and it climbs the walls of my fiberglass pool and at times nearly comes out of the pool cleaning the water line.
    Like Divin Dave stated it doesn't always climb the wall every time. It seems to want to get things done in its own order. Will clean up a wall, then turn and get the waterline for a section and then go back down and then change out to cleaning the cove areas for awhile and then switch out for the walls again, etc. It appears to have a mind of a toddler.
    The brush that came with mine looks like the middle brush in the above post
    12K gal, IG fiberglass, Hayward pump and sand filter, Aqua Rite 20 SWG, installed 2008, Taylor K-2006 w/magnet spinner
    May 2013
    North East Ohio
    959
    Yeah, mine NEVER climbs a wall....it tries and just sits and spins. I wonder if different MFG of FG pools have different top coatings. My steps, seats and floor seem to have a rough edge to them, but my walls are glass smooth.
    I bet I need the other brush, but Maytronics won't offer any swap, etc....boo!
    They did suggest I send it in for warranty if it does not climb, but geez that will take a few weeks out of prime season, guess I need to figure out what to do.
    Aug 2014
    Shallotte, NC
    693
    Climbing the wall, I think, depends a LOT on available suction. Dirty filter or substandard motor condition is probably going to mean it won't climb....
    May 2013
    North East Ohio
    959
    No filters.... Still wont climb
