Thread: Can I Lower Ph with Boric Acid?
    Mar 2015
    Huntington Beach, California
    28
    I took the Borate plunge last week using Boric Acid from dudadiesel, new water, and filters.
    This borated water has been the easiest water to maintain than any other water so far. Thanks to everybody on here that contributed to that good recommendation!
    Can I use the leftover Boric Acid to lower Ph? I did not see it on the Pool Calculator in the Ph section, and didn't get any search results.
    My guess, from what I read using it to Borate, that it's not strong enough.
    Thanks!
    2007 Artesian Island Spa, Bahama 52, 2 pump, 450 gallon, Serial# 75777, Build date 2/23/2007, on Bromine and Borates.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Can I Lower Ph with Boric Acid?
    Use MA instead, save that for later if you need to replenish.
    Essential Links:
    Mar 2015
    28
    Thank you!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No problem!
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Boric acid is a very weak acid so is not suitable for lowering pH. When boric acid is added to water, it mostly remains as boric acid and only some of it dissociates to lower the pH and become borate ion. Adding 50 ppm to water with a pH of 7.5 and initial TA of 80 ppm will lower the pH to 7.3 so even adding enough boric acid to increase borates to their maximum recommended amount doesn't lower pH very much.
