Thread: New pool installation
    May 2015
    MA
    18
    Hi All -
    So I had a new 30x15 pool installed earlier this month and I'm in the process of running the electrical for it. Everything should be straightforward except for the bonding wire. The pool is sitting directly adjacent to a poured slab about 18" away from the pool. I know code requires an 8 AWG bare copper wire buried 18-24" from the pool, about 4 - 6" deep. The slab is 4" deep and sits on grade, and the space between the slab and pool is filled with crushed stone. I assume crushed stone wouldn't be considered proper buried substrate, so i'll have to dig into the soil below for the wire.
    Now I imagine anyone tall enough and outside of the pool that wants to stick their hand in the water will most likely be standing on the slab and not the crushed stone. Do I need to bond the slab, too? If so, how? There is wire mesh below the slab but I don't think i'll be able to tap into it without breaking the concrete. Would this be considered the same as an IG pool with a concrete deck?
    Any advice would be appreciated, thanks.
    Matt
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: New pool installation
    I don't have an answer for you, but wanted to welcome you to TFP! Have you purchased a recommended test kit such as the TF 100 linked in my signature? It will be the best investment you make by taking control of your pool.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2012
    western NY
    1,562
    Yes, the slab should be bonded just as concrete decks around in-ground pools are. This problem has cropped up several times on the forum and there is no clear cut answer. Some people have managed to chip away a portion of an edge to expose the rebar/wire inside the concrete. I once had to saw cut a 1" deep groove into a pad to grout in a bond wire. you may or may not be able to get away without doing it. If you bury the bond loop as close to the concrete as possible the bond may take place between the dirt and the concrete enough that there will be no problem.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2015
    MA
    18
    Quote Originally Posted by danpik View Post
    Thanks for the tips. I have a set of stairs going up to a deck on one side of the pool. I could saw cut a trench below them and bury the bond wire there, in addition to burying the loop right next to the slab. I also though about drilling into the side of the slab with copper lugs. Maybe it would be enough to keep a bond at least a couple feet in board.
    Feb 2015
    Bardstown KY
    139
    Are you doing this for your own safety reasons? Or is your county/city requiring it, and therefore will be inspecting it? If the latter, then I would talk to the inspector and ask what he expects to see. Ultimately, no matter what is deemed safe by someone else, it won't make any difference if it isn't what will pass his inspection.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    May 2015
    MA
    18
    Just doing it for my own safety.. figure better be safe than sorry.. even if it doesn't meet code exactly.
