Thread: Radiant skimmer help
    May 2015
    Kingston/ny
    1
    I have a metric 24' round with the skimmer, installed last year. The bottom of the skimmer, by the hose output cracked this winter. I got a new skimmer but upon looking at how the old skimmer was installed I'm at a lose. It looks like to install a new skimmer I have to drop the liner on the pool which seems like more of an ordeal than I want.
    Would something like a plastic ring and maybe JB /marine/water weld to seal the crack in the skimmer be a smarter and easier solution or should I just bite the bullet and have someone come out and replace the skimmer. Messing with the liner with my low skill level seems like a great way to introduce leaks.
    Thanks and thoughts appreciated.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Re: Radiant skimmer help
    Welcome to the form and someone with more experience with that type of pool will be along shortly to give you some advice.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! Can you update your signature with you pool and equipment info? You can do this in settings. Is this an above ground or in ground pool?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
