Results 1 to 16 of 16
Thread: The 1st time I SLAM'd
    So I've determined that I need to SLAM (as discussed here).
    Starting Point:
    FC 3.5
    CC .5
    CYA ~80 +/- 10
    TA 80-90
    PH 7.5/7.6
    CH 225 [I wonder if this is why I have white streaks coming off a lot of the tiling/stone...??]
    I added 6 jugs of Clorox (121oz 8.25) this morning - I think this should bring the FC up to ~28.
    My plan [please jump in if I'm missing something]: Let the filter run all day, check the FC and CC tonight after sun down and then re-check in the morning to compare. [Does the filter need to run all night as well??]
    If FC has dropped by more than 1, then add enough clorox tomorrow AM to get it back up to ~28. Repeat.
    Advice highly appreciated.
    Thank you
    20,400gal Saltwater, Hayward Aqua-Rite SWG up to 45k gal, IG, Plaster, Cartridge, 2hp 1-Speed Pentair, 152k BTU Aqua Comfort Heat Pump, Well Water.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: The 1st time I SLAM'd
    You would be better off lowering your CYA to 30-50 range. Your PH needs to lowered too before you start slamming. Once your FCis over 10 PH will give false readings.
    Ideally if you are able to test more often in the beginning it will move things along faster. If not then it is fine to test. Twice a day.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Quote Originally Posted by Azgirl71 View Post
    Oops, I forgot to mention that it's a saltwater pool (I've updated my signature). According to this chart, I think CYA of 70-80 is ok?
    The PH was 7.5-7.6 (and I already added the Chlorine) - maybe I'll add a little Muriatic Acid after work? On the SLAM page, it says 7.2-7.5 is ideal.
    Thanks!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    It is safe to lower CYA when SLAM is in progress as you do not use the SWG during a SLAM. It is fine you already added. I am not sure about adding MA once your numbers are above 10FC since you cannot test it to make sure you did not drop too low. I would not worry about it for now.
    Lisa
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Although you can SLAM at 70-80, it takes a huge amount of FC. I would urge you to get to 40, 50 at the highest. But if you would rather haul and buy more Bleach, that is entirely your choice. pH should always be adjusted prior to raising FC level for SLAM.
    Essential Links:
    Quote Originally Posted by Patrick_B View Post
    Thanks Patrick. If the option is to either drain the water and refill - or buy/haul more bleach, I'll go with more bleach. We're on a well and it has a relatively low yield. I bought the bleach in 3 packs at Costco, price is reasonable. Next time I'll lower the PH first - I thought my starting level was ok.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's fine where it is. I totally understand the well. Mine isnt the best either, so just let us know how to help. Lisa (AZgirl) will likely be helping you a lot. She is a relentless SLAMMER, so she knows how it's done.
    Essential Links:
    Measured when I got home this evening - around 530.
    FC 14
    CC <.5
    Not sure if I should bring back up to 28? Or measure when dark and then compare tomorrow morning. Should filter run all night?
    Thanks for helping me learn how to SLAM.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    During a SLAM the goal is to keep you chlorine level at slam level until you pass all three tests.
    Clear water
    Pass oclt
    No CCs
    So yes. You need to bring FC up. I'm right there with ya. Cya is 70 and I'm slamming now.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    AimeeH is correct. You need to keep it at SLAM FC levels. It is probably already mentioned, but is your pool clear? Your.5 CC is considered passing, but it will likely drop to 0 if you let it.
    Lisa
    Yes, pool is clear.
    Quote Originally Posted by AimeeH View Post
    Clear water
    Pass oclt
    No CCs
    Got it. I added 4 more jugs of clorox in an attempt to get FC up from 14 to ~28.
    Seems I over shot it as I just measured tonight (~3 hours after adding the bleach) and it was 35.
    Will check again in the morning to see how far the 35 comes down.
    14 jugs so far - I think I'm gonna need more... Last night the FC dropped from 16 to 3.5 this am.
    Thank you again for the help.
    Quick Question - is it critical that the pump run all night? I think our pump is quite oversized. 2hp. Turns over the pool in maybe 3.5 hours I'm guessing.
    May 2015
    Central Illinois
    41
    The less the pump runs the longer it will take. My pool cycles in 57 minutes and I'm on day 7.
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    Success!
    Measured FC at 630am ~34.
    Turned the SWG back on - will have to play with the % and pump run time now that the chemistry should be good (or on its way).
    About how long does it take for the FC to drift down to its normal level? When can I proceed with water tests that aren't thrown off by the SLAM process? Anything else I should be doing/checking?
    Thanks again for the help - happy to have found this resource.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Wait until your FC is below 10 fr accurate ph readings is all. You didn't mention your cc reading -- was it below .5?
    Just so you know in case you ever have to slam again (hope not -- the slam method requires checking your FC at least every few hours and continually bringing the FC back up to target much more frequently in the beginning than what you experienced/reported this time. Fortunately, you must have caught a problem early, which is awesome!
    Enjoy your clear, clean pool now
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Quote Originally Posted by Swampwoman View Post
    Thanks! Yes, CC was 0 (no change when I added the drops).
    Should I turn the swg off until the FC gets down to normal ranges?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Greta job! I would turn the SWG off until you get to about 8 FC. Otherwise it will take longer to drop low enough to do a full set of test.
    Lisa
