Thread: Pentair Max E Pro Sqealing Noise
    May 2012
    Kitchener Ontario
    2
    Would anyone know what is causing a high pitched squealing noise in my pump? Its intermittent and started last season.
    Its about 7 yrs old and has never been serviced or overhauled.
    TIA.
    40' inground vinyl mountain lake (27,000 gal)/Zodiac SWG/Pentair Max E Pro/Pentair System 3/Jandy Lite NG
    Apr 2012
    151
    Re: Pentair Max E Pro Sqealing Noise
    Could be a couple of things:
    Most likely: A bearing in the motor. They can be changed, but sometimes it is easier to just do the whole motor swap.
    Less likely: Something stuck in the impellar that is creeping out and rubbing on the diverter - just take it apart and see (all 3 scenarios mean disassembling the pump so...)
    Somewhat likely: That model has a diverter held on with SS screws, I have seen them rust out and the diverter get into the impellar. This is especially true on pools with a SWG.
    Personally, I would let it go till you can't stand the noise, especially if you plan on just replacing the motor.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
