Results 1 to 9 of 9
Thread: Nature 2 Fusion issues
    May 2015
    Monroe/NJ
    76
    SO I have a brand new pool - got a SWG to make my life "easier". It's been anything but. Constantly reading "no flow", running at 85%, 24 hours a day, not generating any chlorine. Have had pool company out twice, they are coming out again next week. I know my CYA is still low (40) AND I'm in a very sunny area, but I would expect at least some chlorine reading with 24/7 running at 85%. Plus they keep insisting that it is normal for it to read "no flow" on occasion which, according to the manual it is NOT, and it is on 'No flow' 50-75% of the time, not occasionally.
    Shame on me I didn't do my research or find this website until after pool installed and this was the generator that they typically use so we went with it. I've already removed the mineral cartridge after reading about the uselessness of it on this website, but still issues with flow, etc. I saw other posts Re: sensor issues with this SWG but the service guys insist that this is the dark grey sensor, not the white sensor that was causing so much trouble." Sorry this is rambling- guess my questions are:
    1) could low CYA and sunlight account for no chlorine when running 24/7 at 85% (this pump is rated for 40000 gallons my pool is 33500)?
    2) Is it EVER supposed to say 'no flow'?
    3) Did I buy a lemon?
    My plan is to just use bleach in the meantime and continue to harass them all summer until they admit it's a lemon and get me a replacement. Will have to pursue with BBB I suppose if this keeps up.
    FC 0 Ph 7.2 CYA 40
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    Jul 2013
    Troy, MI
    11
    Re: Nature 2 Fusion issues
    What's your salt level?
    11K gal, fiberglass, 1 HP Hayward tristar pump, cartridge filter, Aqua Plus SWG, 3 MagicStream Laminars
    May 2015
    Monroe/NJ
    76
    Quote Originally Posted by equinn01 View Post
    Oh yeah, sorry
    3800
    Heat Pump
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    It should only read no flow when you initially cut it on.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Jun 2011
    Long Beach, CA
    2,781
    You should not be getting a "No Flow" error ever if the system has enough flow for the SWG.
    What pump do you have? If it is a VS or 2-speed pump does the "No Flow" error occur when it is on low-speed?
    They still have issues with the dark grey sensors, the white sensors had more problems, but this issue has never been properly fixed.
    May 2015
    Monroe/NJ
    76
    Quote Originally Posted by ping View Post
    That's what I thought. Unfortunately I don't have my pump info handy but I am fairly certain it's not a 2-speed.
    I really don't think the water flow is an issue, I have felt it in my gut that it is the sensor from the beginning but they keep trying to tell me otherwise...
    Heat Pump
    Jun 2011
    Long Beach, CA
    2,781
    Your SWG does require a good amount of flow, more than most other SWG's, so don't dismiss the amount of flow as not a problem. Variable speed pumps on low settings, dirty filters, all lead to flow problems with some SWG's.
    May 2015
    Monroe/NJ
    76
    Thank you for that...it is a brand new pool so I would hope they installed the appropriate pump for this generator, but after my experience over the past 6 months their "25 years in the swimming pool business" doesn't seem to equate with competence. I will definitely get myself educated on this pump just as I have the SWG and chemistry. A heck of a learning curve but the more empowered I'm getting with this, the less stressed I'm getting.
    Heat Pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Jim,
    you're coming along with your learning. I agree with ping. Sounds like a bad flow sensor or it could be a component on the control board
    I would def have the PB check it out in more detail.
    Divin Dave,
