Results 1 to 7 of 7
Thread: Hepl on salt
    zzrguy's Avatar
    May 2015
    Setauket , NY
    10
    Hepl on salt
    Ok so I need to salt my pool I've been looking online and I see pool salt and water softener salt both are pure salt so what is the difference beside the price. Will water softener work I ask cause some time the pool salt is not available but the softener salt is plus a lot cheaper.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hepl on salt
    It absolutely will work perfectly and is a better choice because of price. "Pool Salt" costs more because it says pool salt. Its finer, (pulverized) but that's all.
    The only catch is to make sure it doesn't have Iron remover, or resin cleaner labeling on the bag. We usually suggest SOLAR crystals, but any will do. Look for purity, and it will be the same as pool salt.
    Welcome to the forum.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Hepl on salt
    Welcome!
    Recommended Pool Chemicals will tell you what to use to adjust what and how to add it.
    zzrguy's Avatar
    May 2015
    Setauket , NY
    10
    Re: Hepl on salt
    Cool thanks. So basically it will take longer to melt into the water.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hepl on salt
    Yep, but even then it isn't long.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Hepl on salt
    Quote Originally Posted by zzrguy View Post
    If the water is clear and balanced and just awaiting salt, slow melting is not always a bad thing. Are there any children in the house? Hold Diamond Day, where you dump it in and let the kids swim through clouds of crystals they scoop up. They'll mix that salt better than any pump or brush.
    zzrguy's Avatar
    May 2015
    Setauket , NY
    10
    Re: Hepl on salt
    I have a slow leak and the pool was empty this years so I needed to fill it the Pool Guy said don't add salt till we find the leak so I didn't but have been adding shock well the pool got a little funky after the little heat wave we had last week so I'm sick of adding shock so I just want the SWG to be up and running so I can stop throwing money in the pool. I've gotting the cost of chemical down to $250 a year on average to up and run the pool for the year and just with Shock this year I'm over 125.
    What do you guy usually spend a year my pool is 16 by 42with a 20ft long 12ft deep end
