Results 1 to 9 of 9
Thread: Unsure of What this pipe is for by filter
    May 2015
    lake ronkonkoma
    8
    Not sure what this unused unconnected pipe is for. Any body have any idea? It has the red circle around it.
    [IMG][/IMG]
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Unsure of What this pipe is for by filter
    Do you have a floor drain?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    lake ronkonkoma
    8
    I just moved into the house.. pool is too dark to see the bottom, But i believe there is one.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    That one has me stumped.
    What's with the rope?
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    It appears to be teed into the suction side. Do you have two skimmers?
    The other possibility is that someone upgraded and added a second main drain and that's where they tapped in. It does look like sort of an afterthought.
    Currently that side of the suction is shut off. Move that valve 180 degrees and see if the flow from the skimmer stops but the pump keeps working. That will indicate there is a main drain down there. It might help you clear things faster if you have some suction down below.
    May 2015
    lake ronkonkoma
    8
    I do have two skimmers, I have the main drain closed and skimmers open because I believe the main drain is clogged with so much debris at the bottom of my pool. My filter stops shooting out the returns after about a hour., and i have to back wash to get them going again
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    I don't see it teed to the suction sideLooks like a spa air line to me. Is there a spa?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    lake ronkonkoma
    8
    no spa.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It looks to be an air vent and if you don't have a spa, it could be a SVRS line for the main drain. If the main drain gets blocked, this line will allow the pump to suck air and lose prime so the main drain no longer has any pull. Is the main drain line right behind it?
    Mark
