Results 1 to 7 of 7
Thread: Water Feature Plumbing Question and Freezing - with PICS
    Apr 2015
    Wheatfield, IN
    53
    I am going to build a three tier water feature with a 2' LED lit water fall in the middle and on each side a 1' LED lit water fall. I beleive that making with masonry block and then facing ot with a faux stone will be the simplelist approach. All three water falls together are rated at 4000 gallons per hour or about 66 GPM, so I am debating on running 2 1/2'' lines then or stepping up to 3''? Any suggestions? But my real question is how do I install the plumbing so that I dont have the supply lines freeze in the winter? While I am asking that question I am also installing my supply and return lines to the pool this weekend, do I need to slope these lines toward the pool so when I drain the pool below the skimmer in the winter they will drain into the pool? Want to only do this once.
    thanks
    Phil
    Apr 2015
    Wheatfield, IN
    53
    Re: Water Feature Plumbing Question and Freezing
    to the top
    Apr 2015
    Wheatfield, IN
    53
    Maybe a pic will help
    Apr 2015
    Wheatfield, IN
    53
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Water Feature Plumbing Question and Freezing - with PICS
    I don't winterize my pool so no experience with this but here are my thoughts. I don't see how you can plumb a waterfall line and have it drain toward the pool because it will have to go up to make a waterfall. Seems like it would work better to have drain back toward the equipment pad, but I don't know how your ground slopes if your pump is above or below the waterline, etc.
    Apr 2015
    Wheatfield, IN
    53
    Any ideas on how to plumb my water falls so that I can either drain them or how do I prevent the lines from freezing. I plan on making my coping top removable so that I can remove the actual waterfall annually just not sure on the feed water line.???.
    May 2013
    North East Ohio
    959
    Blow out the lines....
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
