Results 1 to 10 of 10
Thread: Riddle me this
    Jul 2014
    Evansville, IN
    72
    Riddle me this
    I am diligently following the way of this site and I have learned a lot. For example, I used to put algaecide in my pool every week and people complained about green hair. I get the savings using baking soda and borax instead of ph up, down, etc, but is adding bleach to your pool daily really cheaper than chlorine feeder?
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Riddle me this
    You can use liquid chlorine or bleach. Both do the same thing and will not mess with other levels like your CYA
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,248
    Re: Riddle me this
    A pool needs to have a certain number of ppm of FC added each day to be safe. If you look at the costs of chlorine sources per ppm of FC, liquid chlorine is nearly always cheaper. And it does not have the side-effects of the tablets. If you want to use tablets, be sure to include the cost and hassled of possibly draining your pool to lower the CYA.
    That said, in areas of the country where the season is short, rain is plentiful, and the pool is partially drained for winter, using the tablets exclusively can be a valid solution ... assuming that you monitor the CYA level and increase the FC level proportionally with the rising CYA. Or use the tablets until the CYA hits 60ppm or so and then switch to bleach.
    You just have to understand what the products are doing to your pool and what the long term ramification might be.
    Jul 2014
    Evansville, IN
    72
    Re: Riddle me this
    Thanks. I am sticking to bleach. Just wondered if it was cheaper. Didn't consider side effects. Thanks
    38,248
    Re: Riddle me this
    If you stay on the forum through the summer, in late July/August we will be inundated with green pools. This is usually because they are using tablets, the CYA rises (which they do not realize) and they do not raise the FC level. To make matters worse, when the pool starts to go green, they may start dumping Dichlor "shock" into it ... well, that makes the CYA rise even faster.
    Mark my words ... happens every year
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Riddle me this
    Quite often it does turn out to be the case.
    Blizzle is right though. Every year I've been here for sure.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Riddle me this
    ^^^^^ yup ^^^^^
    Divin Dave,
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Riddle me this
    Plus algaecide is an added expense
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2014
    Evansville, IN
    72
    Re: Riddle me this
    I aint going nowhere lol. I look at this site and read other's posts all the time. I have learned a ton! Many thanks to everyone!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Riddle me this
    Quote Originally Posted by Darren35 View Post
    Great! Stick around, keep reading posts and solutions to problems. I bet in a month or so the big lightbulb will come on over your head and you will be answering questions.
    Support the site
