Thread: Brand new pool...with a hole in the plaser
    May 2015
    Monroe/NJ
    76
    Pool is less than a month old. Noticed a small hole about the circumference of a pencil today. Other than the frustrating part of not having a brand new pool that is "perfect", is this something I need to worry about? Is it common?
    Recently added muriatic acid to pool- while I brushed shortly afterwards I am paranoid that somehow the acid ate a hole in the plaster- is that even possible?
    I know the pool is still under warranty but is a small hole like this something that pool companies will typically fix or, again, is it an expected and 'acceptable' imperfection?
    I had trouble from beginning to end with this pool company and the thought of getting into it with them yet again stresses me out.
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    38,301
    Re: Brand new pool...with a hole in the plaser
    I highly doubt your acid had anything to do with it ... unless you poured a lot of acid directly on top of where the hole is.
    It could have just been an air bubble, but that sounds bigger than that. How deep is the hole?
    I would certainly consider contacting the pool company to see what they say.
    May 2015
    Monroe/NJ
    76
    It is just below one of the spots where I poured acid, but I followed the instructions from this website- pouring small amounts at a time and this spot is just below one of the returns so it doesn't seem likely. I haven't felt the hole yet but from looking at it, it looks the depth of a pencil eraser.
    Thanks.
    Heat Pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    They missed a spot, sorry. The acid didn't do that.
    Essential Links:
