Thread: New pool in Maryland
    Hello,
    I've been a lurker here for about a month learning all kinds of stuff about pools.
    I waited until today to post because I didn't have a pool.
    Tuesday we settled on the new house with in-ground pool.
    We had a pool inspection, but the house was a foreclosure and the pool hasn't been taken care of in at least a year.
    It was built in 2005 and is a Concrete (gunnite?) pool (no-liner). We had a pool inspection done before the purchase and found out all the info in my sig line.
    The pool had been winterized (the pool inspector double checked it). The level has been dropped below the returns (the pump is below the grade of the pool, so water flows down to the pump). I beleive the pool was winterized for LAST winter, not this winter.
    The pool is covered, and is a swamp. Creatures are living in the pool (frogs, tadpoles, etc etc).
    Here is my question...
    If this was your situation, would you leave the pool alone until spring (which my sig indicates I'm leaning towards), or start treating it now so that the spring clean up won't be so bad?
    It seems to me that without the pump, I'd just be wasting any money (chemicals) I poured into it now.
    My wife has suggested draining it, pressure washing it, and refilling in the spring. I'm aware of the dangers of a pool floating, and I'm advising against it. (She is worried about the ick factor of things in the pool, and doesn't think we can get it clean without draining it).
    Opinions?
    In-Ground. White Marbelite plaster. 21'-7" x 38' Figure Eightish Custom diving pool with 9' deep end. 24,750 Gallons. Pentair Challenger 2 hp pump, Pentair Clean and Clear Plus CCP420 Cartridge Filter, Paramount PCC-2000 In Floor Cleaning system with Debris Canister. Pool/House was a foreclosure that sat dormant for at least 2 years, and was an actual swamp. Using BBB and POP I made it a sparkling backyard oasis. I have a TF100 kit, and I know how to use it (mostly!). This is my FIRST REAL pool, but thanks to TFP, I know what I'm doing! (mostly!).
    Re: New pool in Maryland
    Hi, welcome, and congrats on the pool (and house!)
    You probably won't need to drain. Just about any problem can be fixed, even gross swampiness!!
    Others may have a different opinion, but since it is already covered, if you are SURE it is winterized (lines drained and antifreeze added) I would probably leave it. At most I would try to scoop out some of the muck now, but treating the water is WAY more easily done when you can use the equipment.
    Plus, leaving it all winter will give you time to go to Pool School and get really smart, so your opening will be a BREEZE!!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I agree with MQ. What ever "swimmies" are in the water should die over the winter months. Do tons of reading over the winter, ask your questions, take/make notes and you'll be all set for spring. As a Christmas gift to yourselves I would suggest spending the $$ and getting a reliable test kit ( see my sig)for next year and save yourself a great deal of aggravation Some use the Taylor test kit as well. Both are reliable but the TF100 is sold by one of our members here and the customer service is outstanding
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Nothing to add other than to say Welcome! and enjoy your new home and especially your new pool. Your in the right place!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi and welcome to the forum!
    You've gotten good advice!
    You're done SLAMing when:
