Thread: Robots and FC Level ?
    May 2013
    North East Ohio
    959
    So I could not find a thread exactly asking this, if I screwed up just let me know and lock this.
    My new Dolphin came today and on it was a BIG WARNING not to run in FC above 4 PPM ? REALLY ?
    I assume Maytronics has no clue on CYA vs FC levels...thus this warning might be for pools with no CYA ?
    I've seen a few comments that robots can run just fine up to normal SLAM level, but they were a bit old (the thread not robot)
    What is the "current" thoughts on what levels are safe to run the robot at ?
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Robots and FC Level ?
    They can be used up,to SLAM levels. With my 200+ CYA I ran mine constantly in water with FC in the 20 range.
    I think you hit the nail on the head regarding confusion over FC/CYA ratios.
    Support the site
    May 2013
    North East Ohio
    959
    Ok thanks much !
