Thread: Aerate the pool
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Aerate the pool
    On pool calculator, i got this message:
    To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH.
    Aerating the pool is it bring water in the air or bring air inthe water ?
    Thanks !
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Aerate the pool
    Either one, I either run the pump on my spa without the heater to inject air, or run my fountain to spray the water up into the air. The whole purpose is to increase the area of air to water interface. This will raise the pH without the usual corresponding increase in TA. Then you add acid to lower the pH (and TA), and repeat until desired TA is reached.
    chiefwej
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Aerate the pool
    your process is correct. you can also turn one of the eyeballs up to break the surface. it takes time but eventually you will find a sweet spot where your ph and ta like to live in harmony.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,362
    Re: Aerate the pool
    You can use your eye returns if you can make them break the surface of the water. Or you can rig up a simple PVC aerator (plenty of pictures if you search on TFP) or you can simply use a sump pump placed on the steps with a hose returning the water back to the pool in a splash pattern. These all aerate the water to help raise the pH as you lower your TA with acid.
