Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Coping Upgrade Cost
    May 2015
    Richardson
    10
    Coping Upgrade Cost
    Hi all,
    My wife and I have been dealing Venture Custom Pools in North Texas as part of a $20K pool option with a new house construction, and have been significantly disappointed in the base options that includes (red flagstone coping). To upgrade to a more nuetral tan or brown color (Oklahoma Flagstone), they are wanting to charge over $2k - this seems excessive to us but wanted to ask you all if this is reasonable?
    Thanks in advance.
    Picture below.
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Re: Coping Upgrade Cost
    Seems high but a good price over all for the pool. Oklahoma is standard with out PB and we are in Dallas as well.
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    How big is the pool?
    Seems high to me - if its a big pool and you were moving from brick to travertine than ok. but youre just changing the color of the flagstone?
    May 2015
    Richardson
    10
    Quote Originally Posted by ErikU19 View Post
    Sorry, should have mentioned, the pool isn't very big - 72' Perimeter. I wasn't sure of if there is a big price difference in red colorado vs. Oklahoma.
    May 2015
    Richardson
    10
    Quote Originally Posted by amandahein3 View Post
    Sorry an new to this... What does "PB" mean?
    Mar 2015
    rowlett, tx
    853
    Quote Originally Posted by dad0118 View Post
    Sorry pool builder. I'm very new too!
    Mar 2015
    Tulsa/Oklahoma
    68
    That sounds high to me. We just remodeled our pool. We had Tennessee Flagstone installed for coping. Our pool had no coping to speak of previously. It was just poured concrete that was part of the whole back patio area. They had to saw the edge of our deck off and. Install the new Flagstone. They charged 1500 bucks for the labor for this. The Flagstone was 340 bucks a ton. Which i beleive we only used one pallet (palletized by ton). They already are doing the labor so they shouldnt be charging anymore for that. I can't imagine the Oklahoma Flagstone being that much more expensive. The Tennessee Flagstone we used was more expensive than the typical stuff our PB used. I would ask them to explain the big price difference.
    1972 - 22,500 gallon, In-ground Kidney shape Gunite pool built by Fiesta pools (2015 remodel), Sta-Rite sand filter Model 9462404 side mount ( Triton II TR60 is newer Equivalent), 3.1 sq ft., Pentair 011018 IntelliFlo Variable Speed Pump, Leslies Coppertherm (Raypak) PL 260AEN 260,00 BTU Heater, Anchor Defender Mesh Safety Cover, Taylor K2006 test kit, Dolphin Z5 Robotic Cleaner
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,215
    I want to make sure I'm understanding correctly. Do you mean that getting the pool for $20,000 is part of an option that comes with building a new house? Can you share the specs and equipment that are included for $20K? Is it an inground pool or an above ground pool? What type of chlorination or sanitization are you interested in using? For example, using the typical chlorine method or a Salt Water Generator system (SWG or SWGS), which produces chlorine, to sanitize the pool from germs, etc.
    Whatever information you can give will make it easier to help answer your questions. You can look at the signature information under our posts for tips on the type of information to give.
    Congratulations on your future pool!!!! You're in the right place for information, support, and encouragement - and sometimes a few laughs!!! Take care! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    May 2015
    Richardson
    10
    Quote Originally Posted by SuzfromTexas View Post
    Yes, the $20K was the cost for the option to add the pool as part of a new construction of a house. The pool is inground, and the following is included:
     All plans and permits included
     Standard track hoe soil excavation and removal from level build site
     12” X 12” four bar upper beam/8”-10” gunite walls and floors
     Rebar steel reinforcement throughout gunite structure
     All standard plumbing and electrical work
     Pool depth 3 ’ to 5’ or 3 ’ to 5’ to 4’
     Written lifetime structural warranty of gunite pool shell
     UP to 72 linear foot perimeter pool placed in most level area of yard
     6” X 6” waterline tile from standard Megatel Homes selections
     White plaster interior surface
     Colorado Red flagstone coping
     Three steps into shallow end of pool
     One surface skimmer and three circulation returns--up to 15’ of plumbing from skimmer to equipment
     Dual main drains with safety covers
     (1) standard 500 watt light
     Approximate three foot width exposed aggregate walkway around perimeter of pool--provided by Megatel Homes. No other configuration is available!
     Hayward 1 HP single speed pump
     Hayward 325 SF cartridge filter
     Intermatic time clock with freeze guard
     Start up chemicals and pool school
     Brush, net, pole and basic water test kit
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Seems really expensive to me. Is it something they have a big surplus of, or perhaps leftover from another job, or cancelled job?
    Have you already signed the contract? Paid deposit? This is usually something you need to negotiate before hand, but there are certain avenues you can go.
    If all else fails, call and speak to the owner. Explain that you're a member of this website, and really looking forward to posting your pics of the pool build on this site. Explain your concern for the way the coping will look, and that you've been looking at other DFW build's and that you really like the oklahoma flagstone that the other builders are using in the area. If there is any way we can work it so that the coping looks as good as the other's in this area, I will give you glowing reviews and recommendations.
    I wouldn't necessarily threaten to leave him negative reviews or anything, but just the thought that you are sharing your experience online, may be enough to help you out. A quick search on BBB shows they've had a couple complaints in the last two years, as well as one on ripoff report, so I bet they're interested in positive info being spread.
    Just a thought because honestly, the 2k seems really high for an upcharge regarding what you're seeking.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
    Mar 2015
    rowlett, tx
    853
    If it's how I'm thinking there really isn't an owner to call. Are you building with megatel?
    There really isn't a pool company to call and getwith it's like upgrading the faucets or light fixtures in your house, correct?
    May 2015
    Richardson
    10
    We are building with Megatel, but the contract states that Venture Custom Pools will be building the pool. We were directed to deal directly with them to design the shape and pick out colors, but my assumption was that Red Colorado wouldn't be the standard base color or only base color available, and that the upgrade cost would be so high.
    Mar 2015
    rowlett, tx
    853
    Hmmm yeah seems an odd color to be the only standard. It's like they know most will want to change it so it's another way for them to get a good chunk of change. Definitely call and argue it.
    Hi all,
    Thanks in advance.
    When we looked at stone in Austin, the price per pound was just about equal for Colorado and Oklahoma flagstone.
    Here's a link to a pricelist from the Dallas area that shows them to be exactly equal: http://www.martinstone.net/categories.php?cat=10
    Here's a link to a pricelist from the Fort Worth area that shows Oklohoma flagstone to be less expensive: http://www.whiz-q.com/category/flagstone.html
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Coping Upgrade Cost
    Two things from me:
    They probably ordered a trainload of this stuff so the price was ridiculously cheap and is why they have to charge more for anything else. But who knows.
    Second - the pool described above is bare bones in all regards. This may be fine for you, but if you were to educate yourself on various areas of pool construction here, you'd see that the options included in the base pool package will cause some functional limitations or compromises. If you want to be pointed in the direction of areas to look at for potential upgrades just say the word and you'll likely get lots if suggestions. Kind of like buying the base level car with no options. Most people don't do it for a reason.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    ^^^^^^ what bmoreswim said, spend a couple days on here researching and upgrade for the better, you will like your pool so much more..
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    The pool looks fine to me, perhaps an upgraded pump would be nice, and I'd go for a SWG, but you can alway's add those later if budget doesn't allow for it now.
    Our Build Thread
    May 2015
    Richardson
    10
    Quote Originally Posted by bmoreswim View Post
    Two things from me:
    Thanks for your thoughts, however, our budget and what we want to spend on the pool is what it is - we knew going into the process the pool would be basic but saw some of the pools at other model homes (with Oklahoma flagstone) and figured it would suit our needs. The company just provided me the following upgrade options... prices seem VERY steep:
    Upgrade waterline tile from standard Megatel Homes selection---$1275
    Upgrade to Oklahoma flagstone or flat precast stone coping (Colorado Red standard)---$2195
    Silvermist flagstone coping---$2395
    60% quartz interior pool surface---$2025 (spa add $595)
    100% quartz interior pool surface-choice from several standard colors---$2950 (spa add $650)
    Stonescapes pebble interior pool surface-choice from standard colors---$3625 (spa add $750)
    One ton moss rock waterfall (approximate size 5 length/18 height)---$2350
    Two ton moss rock waterfall (approximate size 6 length/2 height)---$3150
    OR they offered up the following package:
     Upgrade to two surface skimmers & five circulation returns-- helps keep your pool sparkling clean!
     Up to additional 10 skimmer plumbing run to equipment (25 instead of 15)
     Upgrade to Oklahoma flagstone coping
     Upgrade from standard Megatel Homes waterline tile selection
     Upgrade to Hayward On Command control panel with four function puck remote
     Upgrade to 1 HP/2 speed energy efficient Hayward pump
     Upgrade to large capacity 425 square foot Hayward cartridge filter
     Hayward Navigator automatic pool cleaner
     Chlorine tablet feeder sanitizing system
     Overflow line
     Fill line at hose bib
     Upgrade to hand seeded aggregate decking (up to 350 square feet) with underground drainage system and applicable gutter downspout connections
    $10525 a $4,120 savings!
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    One ton moss rock waterfall (approximate size 5’ length/18” height)---$2350
    Two ton moss rock waterfall (approximate size 6’ length/2’ height)---$3150
     Up to additional 10’ skimmer plumbing run to equipment (25‘ instead of 15‘)
     Overflow line
    You're probably going to want the drainage. Is your current builder running drainage to the curb?
    Our Build Thread
  20. Back To Top    #20
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    My first round upgrade suggestions would be (in order):
    2-speed pump -nice energy saver and almost silent on low. Your 1-speed pump will be very noticeable
    Main drain not connected to skimmer
    Salt water chlorine generator if you don't go with a soft stone
    Overflow line
    Others would likely put the upgraded pool surface high on their list.
    As Suz asked, how do you plan to maintain your pool? Yourself the TFP way, service, yourself Pool Store way, etc? And sanitize - SWCG, Bleach, Pucks?
