Results 1 to 9 of 9
Thread: My Oasis Z5 experience....today was 1st day I used it
    I have a fully operations Doheny (Aquabot) AWD robotic
    Last week, I decided to upgrade to a Dophin Oasis Z5
    Let me tell you what a beast the Oasis Z5 truly is...here are some highlights
    - power
    - cleaned my pool in 45 minutes
    - consistently made passes in deep end even with tricky slopes
    - easily went from deep to shallow, vice versa
    - never got stuck on drain cover in middle of pool deep end
    - easy to clean
    - IT WAS CLEANEST I'VE EVER SEEN MY POOL
    - spots the Aquabot never cleaned, Oasis Z5 made a few passes by those "restricted" aquabot areas
    -picked up absurd amount of dirt, sand that I find in my pool every day in S. FLA
    This is one darn good cleaner. This is my first dolphin as well. It was worth the upgrade IMO. I put the Aquabot on Ebay since its only 2 years old.
    My Aquabot was allergic to the deep end. Its light, somewhat floaty, so was unable to gain the proper traction at times to go from my deep to shallow
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: My Oasis Z5 experience....today was 1st day I used it
    Great review!
    Divin Dave,
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by mpk1970 View Post
    - power
    - easy to clean
    Strange, my aquabot cleans my whole pool. Deep, shallow, walls.. Never gets stuck on drains. I wonder why there are so many differences between users and the same units???
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Jun 2013
    Spring, TX
    24
    I just started my first cycle with the Z5 and so far I am impressed. This is my first robot so I have nothing to compare it to besides manual vacuuming and my Polaris 280.
    My pool has gotten unusually dirt due to being inundated with rain for weeks now. It is brushing and sucking up sticky dirt with no issues. I am also pleased with how it it covering the whole pool and scrubbing the waterline pretty thoroughly.
    A+ so far!
    14000 gallon IG w/ Pebble Sheen Blue Surf; Pentair Clean and Clear Filter; Stenner 45MPHP10 Chlorine Pump; Dolphin Oasis Z5
    TFTestkits TF-100 w/ autostir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I cannot say enough good things about these things. Mine's the M5, so it's nearly identical, and a BEAST cleaner as well.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Which Aquabot did you have? I just upgraded from a Dolphin Diagnostic Pro to an Aquabot Turbo T (not Turbo T-jet) last week and felt much the same way you did, maybe it was just the newer generation cleaner, as the Diagnostic Pro was an older design.
    May 2015
    Lewisberry pa
    4
    Dumb question here- I just purchased the m5 - it's our first robotic cleaner. When the guy showed me it in the store it seemed like the handle stayed upright but the one we brought home does not - is it supposed or just supposed to float up when it's in your pool?
    Quote Originally Posted by Jjsmompa View Post
    The arm is going to adjust as it goes up and down walls. Watch this video to see what it does. Hope this helps!
    15,000 gallons in-ground kidney shaped, 15' x 30' Vinyl liner 3.5' to 6.5' deep
    1 ½ hp Pentair Challenger pump w/ Intermatic timer (220V)
    Pentair Sand Dollar Top-Mount Sand filter SD-60
    Pool construction began 3/15/10. Finished 4/03/10.
    BBB Method with Salt (No SWG, possibly next year)
    TFTestkits TF-100 XL & Lamotte Borate test strips
    Add borax to improve feel & prevent algae
    The Pool Calculator
    Quote Originally Posted by Isaac-1 View Post
    http://www.doheny.com/poolsupplies/D...y-Aquabot.html
    Quote Originally Posted by Divin Dave View Post
    Great review!
    Thanks. Surprisingly, I've only had to use it once. When I dont run the waterfall it doesn't become as dirty.
