Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Cant keep Chlorine!
    May 2015
    West Chester / Ohio
    21
    Cant keep Chlorine!
    I have a 25,000 gallon 18' x 36' pool with a Chlorine generator and a 2 HP pump that runs continuously. I just opened the pool 2 weeks ago and can't keep chlorine.
    The water was cloudy but not green when I opened it and phosphates were above 2500. I added over $150 worth of phos-free products and it hasn't dropped. I also added algaecide as specified in the opening chemical kit. After reading here that phosphates dont matter, I'm going to stop throwing that money away in the pool!
    The water is clear with a soapy or almost bial like foam on top in the corners and I can not keep chlorine.
    My current water test (Taken with a Leslie's FAS-DPD kit #81329 as suggested) are:
    FC = .6
    CC = .3
    PH = 7.2
    TA = 130 ppm
    CH = 260 ppm
    CYA = 40 ppm.
    Salt = 3200 ppm (200ppm lower then the chlorine gen considers optimal)
    Any suggestions would be greatly appreciated! I feel a little lost and am sick of the pool stores playing "trial and error" with my money!
    Dean.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Cant keep Chlorine!
    Welcome to TFP. I would say the foam is probably from the algaecide used. You need to get the FC up using 8.25% bleach, no easy pour splash less or scents.
    My pool was cloudy and not green too. I SLAMmed it following the SLAM process exactly. I usually even over shot my FC target. It took me 13 days, but it is pretty now. There is a link with pics in my signature.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    West Chester / Ohio
    21
    Thanks AZgirl! I was planning on doing just that now that I have a test kit that I can measure FC. I know every pool is different, but I have no idea how much bleach to start with. 1 bottle? 5 bottles? Do you have a suggestion on how much to try in the first wave? Thanks again! I really appreciate it. -Dean
    25,000 Gal Vinyl Lined In-ground pool. Inteliclor IC40 SWG, 2hp Pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Dean,
    There are not "waves", a SLAM is a continous process where the chlorine is raised to shock level and maintained there until everything growing in the water is gone.
    Read the instructions and all of the levels are referenced
    http://www.troublefreepool.com/conte...tain-shockingl
    Support the site
    May 2015
    West Chester / Ohio
    21
    Tim5055, I understand that I am trying to hold a level, however I'm not going to stand over the pool and check it every 5 min! It states to check it between 2 and 24 times a day. SO, The first time am I starting with 1 gallon jug or a 55 gallon jug? I'm just looking for a starting point to give me an idea how much to have on hand.
    A box full, or a shed full of bleach?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would have at least 10-15 on hand to get you started. Your pool is pretty big.
    In the beginning if you are able to check levels every 2 hours it will help. If not then at least check morning and evening.
    Lisa
    May 2015
    West Chester / Ohio
    21
    Thank you Azgirl! That's what I was looking for! I'll buy 15 gal tomorrow and shouldn't have any problems checking it every 2 hr over the weekend.
    Thanks again!
    38,280
    Sounds like you may not have discovered PoolMath yet. That will calculate and tell you how much bleach you have to add to reach a given target FC level.
    With a CYA of 40ppm, you need to maintain a FC level of 16ppm.
    If you are starting at basically 0 FC, it will take 603 oz of 8.25% bleach to reach 16ppm ... about 5 of the 121oz bottles. Or 498oz of 10% ... almost 4 gallons.
    After that you should not have to add as much each time as the FC will not likely be 0.
    May 2015
    West Chester / Ohio
    21
    You are right! I hadn't found that! That's a great tool. Thanks!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Quick tip, dean.
    It you start out frequently testing and bringing it back up on the weekend, your whole slam will move faster
    Think of it this way: every minute that it is below 16 means algae can outstrip the bleach/chlorine. So if you dose to 16, go back in 2 hours, and its at 12, then a good portion of those two hours are actually below slam level.
    But after the first while, the time and amount it drops will improve. So for the first bit, its worth the babysitting on the front end to make it quicker on the back end
    It will also help to dose it to a few ppm higher than your target...that will help it spend more time killing" at target.
    Hope that helps you turn the corner quickly! Memorial weekend awaits
    Cheers to clear.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by deanWesterburg View Post
    Thanks again!
    No problem. That will at least get you started.
    Lisa
    May 2015
    West Chester / Ohio
    21
    Thanks swamp woman. Great advice. Picked up 15 gal. The cashier at walmart looked at me a little funny. ready to start tonight. Thanks again everyone!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Keep us posted and we love pictures!
    Lisa
    May 2015
    West Chester / Ohio
    21
    What a difference even 1 day has made!
    Prior to SLAM @ 7pm
    TC=.6
    CC=.4
    Begin SLAM @ 5/15/15 8:30 PM
    TC=16.5
    CC = 1
    Added 60 oz Bleach for expected reading of 18.1 if no loss on next round
    5/15/15 @ 10 pm
    TC= 16.5
    CC = 1
    Drop of 1.6 from post CL add @ 7pm. Added 60 oz = TC of 19.7
    5/15/15 @ 11:30 pm
    TC = 19
    CC= 1
    Loss of only .7 Adding 121 oz to get through the night. 22.2 new total
    5/16/15 @ 7am
    TC= 23
    CC= .5
    I gained .8 TC overnight because my SWG is on. Should I have the SWG on during this process? If so, what setting? I'm guessing I should disable it for the overnight test otherwise I'm not finding the true loss overnight. Is it just me or do I sound like I'm not too far off my stopping point?
    Thanks for the help!
    May 2014
    Franklin, NC
    9,184
    Generally we advise to turn the SWG off during a SLAM. You are adding so much chlorine manually that there is no need to use it. The cell has a finite life, so,save it for after the SLAM.
    How does the water look? I would turn off the SWG, continue the SLAM today and do an OCLT tonight. My guess is you will pass.
    Support the site
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    One other thing that looks like it was not brought up and with numbers like .8. What size sample are you using? The 10ml test is accurate enough and should only give you a whole number or .5. It will also save on you testing regents.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    May 2015
    West Chester / Ohio
    21
    Thanks Tim. After I posed the question about the SWG I turned it off. I got thinking about the OCLT and thought I'm never going to get an accurate reading if I'm constantly adding to it!
    I was thinking the same thing you were. Continue today and see how much I lose tonight. Thanks for confirming the decision.
    Water was a little cloudy last night. I vacuumed the entire pool by hand last night and again this morning and have brushed all the side walls twice i the last 12 hours. The water looks pretty clear right now. Pump pressure is up a few PSI but still well below the point of needing to backwash.
    Thanks for everyones help. I feel so much less enslaved to the pool store with your help and the results I am already seeing! Wish I had checked here about $300-$400 of chemicals ago!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You are doing great Dean! Keep it up and you will be swimming in no time!
    Lisa
    May 2014
    Franklin, NC
    9,184
    Well, if you or anyone who feels the forum has added value to them would like to,the site accepts donations to keep the lights on and electrons flowing.
    http://www.troublefreepool.com/threa...-com-Supporter!
    Heck, it's lees than a normal trip to the pool store.
    Support the site
  20. Back To Top    #20
    May 2015
    West Chester / Ohio
    21
    Quote Originally Posted by jcowart View Post
    Yea, I switch to the 10ml sample after when I realized I'm going to run out of reagents before I finish my SLAM! More than half the R-0871 (FAS-DPD Titrating Reagent) is gone as well as half the R-0013 (Cyanuric acid reagent) and I just bought the kit Friday! Just ordered more on Amazon. Thanks for the tip!
