Results 1 to 15 of 15
Thread: Muratic Acid
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Arrow Muratic Acid
    Today I went to Home Depot to buy more muratic acid. I figured I would get the one in the paint section since it would be stronger. However, I did not buy it since it did not have a % anywhere on it. I even asked the guy in the paint department and all he said was when he uses it that he diluted 4:1 which did not help me any. I ended up just getting the Kemtek pool MA 14.5% like I had already been using.
    Does anyone know anything about this?
    http://t.homedepot.com/p/Klean-Strip...006/202690263/
    Looks like Lowes carries the 31.45% MA, so when I need more I will go there as it will be cheaper and last longer. I am still curious what anyone might know about the one I linked for Home Depot though.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Muratic Acid
    Azgirl,
    Ive looked at the Green MA at Home Depot. Its just weak Muriatic Acid. There is really nothing 'green' about it.
    Its marketing hype. If there is anything green about it, its that you dont need as much soda ash to deactivate the acid after washing concrete, bricks or any other type of masonry with it. I dont necessarily see that as being advantageous though.
    here is a link to the mSDS on it.
    http://www.homedepot.com/catalog/pdf...9abf30f5c6.pdf
    Divin Dave,
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Muratic Acid
    Thanks Dave. I noticed Lowes carries both a 31.5% as well as a "green" version. The green version at least states it is 15. something. I looked at the MSDS sheet, but it did not make mush sense to me....lol
    Lisa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Muratic Acid
    that MSDS says the controlled chemical is Hydrolochloric Acid < 25% content.
    So, Its the 14 something Im sure.
    Muriatic and Hydrochloric are the same thing. Except that hydrochloric is a more 'pure' acid with fewer contaminants. Hydro is better suited for chemistry labs and such things where contamination can skew results or quality if used in manufacturing... muriatic better suited for washing masonry and other stuff around the house...
    Divin Dave,
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Muratic Acid
    Home Depot carries the the 31.5% in the pool section. It's way cheaper than the green version in the paint section too.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Muratic Acid
    Quote Originally Posted by Divin Dave View Post
    Thanks. I did see that on the sheet.
    Quote Originally Posted by Defgufman View Post
    My Home Depot only carries the KemTec 14.5% in the pool section. I even asked someone working in the pool and garden if they had anything stronger and they said it would begin paint if they did.
    Lisa
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Muratic Acid
    As long as the weaker 14-15% acid is proportionately less expensive, then there's no problem using it and it will fume a lot less. Of course, it's more weight to carry but if you don't need a lot of acid and don't want as much fuming, then it's a reasonable choice to use. Again, just check on the price since some places charge nearly as much for this half-strength acid.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Muratic Acid
    This is one place pool stores are helpful. They usually have 31.45 for about $ 1 less than hardware stores. Here anyway.
    You may not wish to support them, but thats a personal choice.
    Essential Links:
    Jul 2012
    Herndon, VA
    419
    Re: Muratic Acid
    Quote Originally Posted by chem geek View Post
    Just got back from Lowes....they have the "green version" for the exact same price as the regular. And the green version didn't have the strength listed anywhere on the bottle.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Muratic Acid
    That's just rotten.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Muratic Acid
    Quote Originally Posted by GuinnessPhish View Post
    Their web page says it on the page, but could not find it on the label either place looking online.
    Thanks, I appreciate it.
    Quote Originally Posted by Patrick_B View Post
    Yes this is true. I would have to go when my guy that knows what I did is working though as the manager would go crazy on me...lol
    Lisa
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Muratic Acid
    The kleanstrip.com site states in the FAQs for Green Muriatic Acid that the product is 20%.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Muratic Acid
    Thanks
    Lisa
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Re: Muratic Acid
    Good info. We have four local pool stores, and one is closing because of retirement. It was the only one that sold Muratic acid. I could get a case (4) for 20 bucks. Guess, I will try Lowes. The pool section at my Home Depot is like one rack outside. They don't seem to carry it, and only have the 'green' stuff in the paint section.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Muratic Acid
    That's a good price, too bad they are closing. Very, very odd that the others don't sell MA. But, hey they make a ton more on dry acid. Not from me though.
    Essential Links:
