Thread: liquidator hookup to intelliflo
    Oct 2007
    Central Texas
    Has anyone using a Liquidator hooked up a line to the drain plug on an Intelliflow? If so, do you remember what size the fitting needed to be? NPT is such a PITA. It looks like 3/8 or 1/2 NPT. I know I could take the plug to the store but that means the pump is down for 1/2 day and I am still running 24x7 during the plaster curing period.
    thanks if you happen to remember
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Dec 2007
    Central New York
    Re: liquidator hookup to intelliflo
    I think it is 3/8 inch. The washer is listed as 3/8 ID X 7/8 OD.
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Most drain plugs are 1/4 NPT. Never looked on the Intelliflow but it's fairly standard.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
