Results 1 to 9 of 9
Thread: need verification
    May 2012
    Las Vegas, NV
    92
    need verification
    So I took a sample to a pool supply store which they provided me a electronic readout.
    Total Chlorine: 0.0
    Free Chlorine: 0.0
    pH: 8.0
    Total Alkalinity: 155
    Calcium Hardness: 375
    Stabilizer: 0
    Total Diss. Solids: 3300
    Salt: 3370
    Shock Treatment: 0.0
    So they told me to buy and do the following.
    Day 1 - Natural Chemistry Instant Conditioner- 1 Gal (spread around the pool)
    Day 2 - Poolpals PH Down 3lb ( Pour 2pts 9 0zs deep part of pool)
    Day 2 - 1lbs W&W Super-Chlo (add 1lbs to a large bucket of water and pour slowly around the perimeter)
    does this sound right? I just want to make sure that the advice given by the pool person is correct before I continue. So far I just completed day 1 adding the instant conditioner.
    Is this safe for the saltwater?
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Donldson's Avatar
    NW Ohio
    2,892
    Re: need verification
    Your salt level is higher than your total dissolved solid level? That is impossible (salt is a dissolved solid) and a great example why we say that pool store testing is worthless.
    The TFPC method is mutually exclusive to the method of taking your water in to a pool store and dumping in what they sell you. So if you choose to go that route then we can't offer much advice or opinions on what they tell you. I see you have been a member for a few years, have you checked out the Pool School or the basics of the TFPC method yet?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2014
    15,056
    "L_R", I'm just burning a few minutes on-line so I thought I'd reply as well ...... Donldson is spot-on. Unless you just need to buy some liquid bleach, acid, or a pool accessory, stay out of those stores! They will suck your checkbook dry and have you running in circles. They did that to me with all their fancy computer printouts and advice for two years. The ABCs of Chemistry, Pool School, SLAM, and pool calculator on this site are the most valuable tools in your arsenal. Stay with them and you won't regret it.
    Casey's Avatar
    SW PA
    10,427
    What you need is a reliable test kit which you can find in Pool School. Pool School is the link at the top,right of every page and it will help you understand what we will be telling you to do to understand your Pool. If you don't make the effort to read it try to understand it, ask questions and have your own test kit, then we'll all get flustered. Most importantly, we won't be able to,help you.
    So, if you could take some time and read the ABC'S of pool water chemistry and order a TF100, you too can break away from the pool store n swim in crystal clear water.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Day 0: Don't buy any of that junk
    Day 1: Get yourself one of the test kits we recommend here
    Day 2 and all the rest: Take control of your own pool a heckuva lot cheaper following our recommendations and enjoy!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I second what WoodyP said! It will be the best move you ever made.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    South Park, PA
    39
    I started following the TPFC method this year and my pool is absolutely fantastic.
    Last year was a nightmare. Pool store advice...I am never going down that path again!
    Get a test kit and take control. And ask lots of questions. They will all get answered!
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    May 2012
    Las Vegas, NV
    92
    thanks for the comments/feedbacks. I registered years ago but never got a pool and forgot everything about it. I ended up resetting my password since I couldn't remember it.
    I feel like I got suckered and wasted $52+gas. I will buy the TF100 tonight and try to read as much as I can. I could have bought it already with the money I wasted at the pool store.
    so what can I do now. Should I add what I bought and just wait for the test kit or avoid it until the kit arrives?
    K-2006 TEST KIT
    Casey's Avatar
    SW PA
    10,427
    If you bought any junk at the pool store, see if you can return it for liquid chlorine, muriatic acid and or CYA.
    Do not add anything major until You have the test kit in hand to get a full set of test results. Use pool math to calculate 2ppm of FC to hold the pool,over til the test kit comes in.
