Thread: Pentair Intellichlor IC40 Fuse info
    MattByThePool's Avatar
    Mar 2015
    Kempton
    1
    My Intellichlor IC40 blew the fuse at the bottom of the power box. I went to take it out and it broke apart.
    I got the metal part out the holder and I can see that it is 10A 250V fuse but I don't know the length.
    Is is a 5x20mm fuse? Slow blow or fast blow?
    Would these fit the holder?: http://www.ebay.com/itm/5pcs-10A-250...item3cdae2f7c9
    Thanks!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pentair Intellichlor IC40 Fuse info
    Hi Matt,
    its a slow blow fuse.
    Afraid I couldnt tell you if the fuses in that link will fit or not.
    Quote Originally Posted by MattByThePool View Post
    Thanks!
    Divin Dave,
