Thread: 2 speed pump switch
    SW Georgia
    300
    2 speed pump switch
    I will eventually install a 2-speed pump for my pool.
    Will a typical in-ground pool pump prime on low speed? If it will then below is a mute point. If it will not please keep reading.
    I want my new pump to run on high speed for the first 10 minutes to make sure it is primed before and automatic switch switches the pump to Low Speed. When the pool cuts off for the day/cycle I want the switch to default back to the high speed setting so as to repeat the process the next day/cycle. Is there a switch out there that can do this?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    38,301
    Re: 2 speed pump switch
    A pump should never lose prime when it turns off, unless you open up the system. If it is, then you have a leak somewhere.
    I manually run mine on high to prime, but had no problems after that just leaving it on low and letting it start in low. Now that I have a ProLogic, it automatically runs on high for a few minutes before switching to low, although like I said, this should not be required.
    You can buy timers where you can set the on/off and set the high/low switching if you really want this for some reason.
    SW Georgia
    300
    I agree it should never leak but sometimes it does and it does not give me any warning. So this switch would just be a precautionary step to protect my pump should I lose prime for some reason. Thanks for the reply
    Apr 2012
    151
    http://www.amazon.com/gp/product/B00...d_i=B001DSEC7A
    This is what I install for this instance...
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
