Thread: Pool Filter Cover
    May 2015
    Las Vegas, NV
    2
    Pool Filter Cover
    I cannot remove the cover off of my pool filter to clean the filter. The black ring around it will twist off but the cover itself will not come off. The filter is made by Aqua Pro. Air valve on the top is open. Thank you for your help.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Filter Cover
    Welcome to TFP!
    We're going to need a little more information. What type of filter is it? Sand? DE? Cartridge? Do you have a model number?
    Speaking of details, add your pool details to your forum signature so it's easier to help. To change your profile and/or signature, select "Settings" (top right under Pool School button). Scroll down (left side) to "My Settings" & Edit Signature.
    Isolated Spa - 345 Gallons
    May 2015
    Las Vegas, NV
    2
    It is a cartridge filter model 59721-AQP1. Aqua pro systems.
    Feb 2014
    Central Minnesota
    5,080
    The cover should come off when the locking ring is removed. You may have to wiggle, tip the top of the filter back and forth a bit to loosen it from the lower o-ring inside. To prevent it from being sticky again, lubricate the inner o-ring with silicone based grease before reinstalling.
    Check out your filter's manual for details. http://ecoaquapro.com/wp-content/upl...ter-Manual.pdf
    May 2015
    Monroe/NJ
    76
    it sounds like you may just have to give it a little elbow grease- was having the same problem, was afraid I'd break it if I pulled oto hard but after checking and being pretty confident that it was turned into the open position, took my chances and gave a good hard pull- it came off. Good luck!
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I have the same problem. Although I keep mine lubed it has a lot of suction and I have to pry mine off with a putty knife. Probably not recommended!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
