Results 1 to 12 of 12
Thread: Aquarite SWG accuracy salt reading ??
    Feb 2014
    Upstate, NY
    390
    I know this has been asked before, for some reason I couldn't find the answer I was looking for. Is there any accuracy to the salt level display on an Aquarite SWG ?? Currently my display shows 3400 ppm of salt. Just curious. My test kit is telling me I'm at 4000 ppm.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    christo's Avatar
    Aug 2014
    bannockburn/md
    9
    Re: Aquarite SWG accuracy salt reading ??
    mine if pretty accurate - though it takes 24 hours to truly register a change. it is within 100 ppm compared to store testing and my test kit.
    ~20K gal, IG 1980s sylvan concrete with hot tub and love seat, pentair intelliflo vf pump, 48 sqft hayward de filter, raypak ng heater, hayward swimpure plus SWG, dolphin deluxe 4
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by christo View Post
    Wow thanks for the reply. I'm way off right now.
    38,524
    All salt tests and the SWG readings are +/-400ppm ... christo is just lucky My test always reads up to 600ppm higher than my SWG does.
    If the SWG starts to read even lower from what the test shows, then I know I may have a problem to deal with.
    Feb 2014
    Upstate, NY
    390
    OK thanks. The 1st test actually was 600 ppm higher than the SWG display. My 2nd test revealed 3800 ppm of salt, the SWG is displaying 3400. So +/- 400 ppm seems dead on. Thanks again.
    38,524
    If the SWG happens to be 400 low and the test happens to be 400 high ... you could easily be off by 800+ppm
    Feb 2014
    Upstate, NY
    390
    How accurate is the Taylor salt kit ?? My head is starting to spin LOL
    38,524
    +/- 400ppm ... they all are.
    Feb 2014
    Upstate, NY
    390
    Thx.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    If the SWG is happy and making chlorine then everybody is happy.
    Feb 2014
    Upstate, NY
    390
    Yep, all is good. The SWG is displaying 3400 ppm. My 1st test revealed actually over 4000 ppm. Initially I thought I was way high in salt. I do have a slight salt taste in the water. As you said, the SWG is working fine, all is good. Thanks everyone.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    It's a problem when the SWG starts reading too low and you have to add too much salt to the water to keep it working. They don't work under 2600 ppm so your SWG could be reading 2500 and you may have 3200 salt in the pool. Then you add more to keep it working but the water will keep getting saltier.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
