Thread: I accidently put splash proof Clorox in my pool.
    May 2012
    Oconee, Georgia
    82
    It was mixed in with the other bottles I put about half a gallon or so before I saw it foaming. What will this do to my pool?
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    38,475
    Re: I accidently put splash proof Clorox in my pool.
    You and many others before you
    It will just foam for while. No real harm.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Just give it time, it will filter out. You're not the first, no worries just annoying, huh?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    No permanent damage. Time and chlorine will oxidize the suds away. Maybe go a little higher tha normal on the Fc to hasten things.
    May 2012
    Oconee, Georgia
    82
    They should make the bottles look different
    I really can't tell I put it in. It was just foaming when I first put it in
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Meh...it will go away soon enough if so.
    Essential Links:
