Thread: Support for side burner
    Continuing my build. Just curious if a single drop in side burner needs vertical support. Going to lay two layers of hardibacker for the countertop and will support the burner on the front wall and a horizontal brace across the back. Does the horizontal need a vertical stud and do the sides need a brace as well or will the hardibacker provide enough support
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Support for side burner
    Welcome to TFP!
    I built what sounds like a similar setup to yours, right down to the hardibacker. Only difference is that I have a 2-burner side burner with an integrated prep-area and storage drawer. I did go ahead and add vertical supports in the back and along the sides. With a single-burner (unless it's made of cast iron) you should be fine supporting it the way you have described.
    Thanks much!
    Jan 2013
    Friendswood, TX
    320
    Do you plan on putting anything heavy?
    To to let you know I have a Primo ceramic smoker on a shelf with no vertical support below. Just a shelf. That thing weighs almost 200 lb.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
