Thread: Should I increase my CYA level?
    May 2015
    Chesapeake, VA
    14
    Forgive me but I left my notebook with all of my readings at home...I believe ph was 7.4, calcium was 240ppm, FC was 5ppm, CC was 0ppm. I definitely know that CYA was approx. 45ppm.
    That said, we have a Pentair IC40 SWG and our pool is in the sun all day. No trees or anything to block the sun. It's already 80s every day here, summers are 90s every day. Does 45 seem too low?
    I plugged my numbers in to the Pool Calculator and it said that I would need about 135oz of stablizer for every 5ppm CYA that I would like to add.
    Recommendations? Go to 50? 60?
    20,000 gallon pool with liner
    Hayward DE6020 filter
    Pentair IC40 SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Should I increase my CYA level?
    Yes, you have a SWG so I recommend a level of around 75 CYA
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Yes, need to increase it. Here is the Water Balance for SWCGs
