Results 1 to 11 of 11
Thread: Few questions before I order my testing supplies
    May 2014
    United States
    9
    This is my second year with a pool and I'm going to finally buy a FAS-DPD kit. I'm looking at the Taylor 2006 with free 2 day shipping on Amazon for $55 vs. $76 for the TF-100 (with shipping). I already have an OTO test kit and DPD tablets.
    my question since the 2006 only has ~25 FAS/DPD tests could i use the OTO or DPD tablets daily and check FAS/DPD every three or four days? my season will probably run the rest of this month and June, July, August so theres about 100 days or so for testing.
    sorry if I left out any pertinent information.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Few questions before I order my testing supplies
    Store your TF100 inside and use it again next year. And the following spring buy the refills cheaper.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by HappyHampy View Post
    Just to answer your last question, sure you can. I advise doing the other (FAS/DPD) until you can accurately predict what readings you get with it. Once you know your pool well enough, you can do that.
    Essential Links:
    May 2014
    United States
    9
    thanks for the advice. my pool is green right now but I plan on draining it completely, scrubbing, then refilling but just in case I get some algae I want to have the proper testing supplies. I did fine last year with just the DPD tablets. It was crystal clear all year making daily bleach adds. hopefully I'll be just as lucky this year.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    What kind of pool do you have?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good deal Hampy,
    You'll still want to Start a SLAM to make sure you get all the Algae killed once it's full again. Just to be sure, and get a good clean start.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I also wanted to add that I recommend the TF 100 you get larger amounts of reagents
    Lisa
    May 2014
    United States
    9
    I have a 14' x 42" Intex. approx. 4000 gallons. I lowered the water level to about 6 inches when I closed up last year, but with all the rain I'm up to about 8 inches or so now. My plan is to get the pool drained hopefully tomorrow and scrubbed. then start the refill and hopefully be done filling sunday. get my CYA right, PH right then slam and hope for the best with the OCLT. If I run into problems I will be back asking you good folks for help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    When you scrub, add some Bleach to the water and it will help tremendously.
    Please add those pool details to your signature line. We will be here...so let us know.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Don't drain it all the way. Leave about 1 foot of water. If you drain all the way you risk damage to your liner.
    Lisa
    May 2015
    Houston/Texas
    6
    I also recommend the TF 100...better bang for your buck. I like to use FAS/DPD and OTO but I am not a fan of tablets. (FWIW I maintain a similar pool to yours and switched it to salt water and have never looked back.)
