Results 1 to 7 of 7
Thread: Hose keeps falling off... any suggestions, please!!
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Question Hose keeps falling off... any suggestions, please!!
    This is my first time getting my pool opened and running by myself, I have everything hooked up and it was pumping/running just fine... a half hour later I glance outside and the water level had drained to almost below my skimmer... leaving the pump to run with out a lot of water and the water pouring out of the skimmer hose connection... Grrrrrr... twice now.
    Why won't the hose stay connected to the skimmer "down pipe"... I am afraid if I tighten the hose clamp any tighter it will just crack the white plastic piece coming off the skimmer... What should I do, I don't trust it at all now. Scared if I walk away it will fall off again and I will lose all the water again, burn out the pump and more or worse.
    Any suggestions!? Am I forgetting something? Should I add a hook or support for the tubing/hose/pipe??
    Thank you!
    24 ft R, Niagara by Asahi Pools, ABG, 13500 gallon, hayward 1hp single speed pump, swim pro sand filter.
    Jun 2012
    western NY
    1,562
    Re: Hose keeps falling off... any suggestions, please!!
    You need to tighten that clamp. There is no way you will be able to tighten it enough to crack the fitting. The clamp would strip out before that could happen. I an 6'2 - 250 lbs and I crank on my hose clamps as tight as I can without any problems
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Using a nut driver or small ratchet will help if you have been using a screwdriver.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    TinaJ718's Avatar
    Jun 2013
    Minnesota
    18
    Really? Man I feel like I'm wrenching on it... so it doesn't need anything else. Just tighten it and it should stay, it's really just the force of the water continuing to push the hose off?? Thank you!
    How old is the hose? I used to have this problem till I bought a new hose. I actually got a new hose because the old one was cracking. Then I realized that the fitting was much better on the new one.
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by Stonedrie View Post
    Ditto. I had a hose that kept blowing and stopped when I replaced it. They are not that expensive.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    Buy 2 new clamps and double them up.
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
